Vlan mapping
I need to know what the limit vlan mapping we can do on the following equipment.
CISCO#sh ver
Cisco IOS Software, ME340x Software (ME340x-METROIPACCESSK9-M), Version 12.2(55)SE3, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Thu 05-May-11 17:37 by prod_rel_team
Image text-base: 0x01000000, data-base: 0x02F00000
ROM: Bootstrap program is ME340x boot loader
BOOTLDR: ME340x Boot Loader (ME340x-HBOOT-M) Version 12.2(44r)EY, RELEASE SOFTWARE (fc1)
CISCO uptime is 1 week, 6 days, 1 hour, 2 minutes
System restarted at 10:09:26 WEST Wed Jun 6 2012
System image file is "flash:me340x-metroipaccessk9-mz.122-55.SE3.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
cisco ME-3400EG-2CS-A (PowerPC405) processor (revision A0) with 131072K bytes of memory.
Processor board ID FOC1342X0U1
Last reset from power-on
4 Virtual Ethernet interfaces
1 FastEthernet interface
4 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 00:27:0C:F3:0D:80
Motherboard assembly number     : 73-11448-08
Power supply part number        : 341-0208-01
Motherboard serial number       : FOC134225KP
Power supply serial number      : LIT13390233
Model revision number           : A0
Motherboard revision number     : A0
Model number                    : ME-3400EG-2CS-A
Daughterboard assembly number   : 73-10798-03
Daughterboard serial number     : FOC13410WN4
System serial number            : FOC1342X0U1
Top Assembly Part Number        : 800-29839-01
Top Assembly Revision Number    : B0
Version ID                      : V01
CLEI Code Number                : COMX200ARA
Daughterboard revision number   : A0
Hardware Board Revision Number  : 0x04
Switch Ports Model              SW Version            SW Image
*    1 4     ME-3400EG-2CS-A    12.2(55)SE3           ME340x-METROIPACCESSK9-M
Configuration register is 0xF
Can you help me, please?
Thanks you
rahurao
Level 5
Level 5
Hi Luis,
I checked for the limitations for the Metro Ethernet 3400 and found the below limitations:
Platform Support
•802.1q-tunnel-port mode: Cisco ME 3400E and ME 3400 switches.
•Selective Q-in-Q (support for 1-to-2 VLAN mapping, but not 1-to-1 VLAN mapping): ME 3400E switches only.
•802.1ad UNI (only C-UNI 1-to-2 mapping): ME 3400E switches only.
You can refer the below links for reference:
http://www.cisco.com/en/US/docs/switches/metro/me3400e/software/release/12.2_44_ey/configuration/guide/swtunnel.html#wp1052756
http://www.cisco.com/en/US/docs/switches/metro/me3400e/software/release/12.2_54_se/release/notes/OL22235.html
I didn't found any other limitations on the same.
Rahul K. Rao
Hello Rahul,
Thanks for your response.
Loot that output:
sh platform vlan mapping usage
Platform Vlan Mapping Information
Port ASIC 0
Region Name        | Min | Start | End | Used | Avail | Total | Percentage
Loopback             0     0       0     0      0       0       0%
Drop                 0     0       506   0      506     506     0%
Match 2 vlans        0     506     1012  0      506     506     0%
Match 1 vlan         0     1012    1518  0      506     506     0%
Default operations   16    1518    1534  0      16      16      0%
Vlan blocking        0     1534    2040  0      506     506     0%
Catch all            8     2040    2048  8      0       8       100%
* = region needs compacting
Section Total
0       2048   8      2040    2048    0%
What you say?
I think we have 2048 vlan mapping totaly .......
