Vlan mode access
ShaunEini3096
Visitor
When you configure an interface on Cisco 3850 switch to be in a specific vlan you enter :
1)switchport mode access
2) switchport access vlan ...number...
why do we need both commends if the second command is enough?
Mark Malone
first command make its a l2 switchport ,second command adds the vlan , no switchport makes it l3
second will work just on it own though too
meahmedhassan
Frequent Visitor
Frequent Visitor
the command switchport mode determine the mode of the port , if access or trunk and the default there is dynamic negotiation to choose mode , if the mode is access either by the command  swtichport mode access or dynamic  then the second command switchport access vlan X  means if the port decide to be access then use vlan x , so you write the second command only switchport access vlan X  but you depend on negotiation to decide the mode access .
switch(config-if)#swichport mode ?
access Set trunking mode to ACCESS unconditionally
dynamic Set trunking mode to dynamically negotiate access or trunk mode
trunk Set trunking mode to TRUNK unconditionally
Switch(config-if)#sw access ?
vlan Set VLAN when interface is in access mode
Pedro Arrieta
Level 2
Level 2
Hi Shaun,
- The first command is to set the port in access mode, if you don't use it, you depends on the mode dynamic and the other side.
- The second command is to set the vlan on the port.
