Showing results forĀ
Search instead forĀ
Did you mean:Ā
VLAN on WAN interfaces
ankitohc
You can see all the WAN interfaces. Can we create the VLAN at the WAN interface? How it's different from making the VLAN on switches? What is the difference between creating VLAN on switches or WAN interfaces.. Sorry for this dumb question. I am learning CCNA so I thought I should ask this
M02@rt37
Hello @ankitohc,
In the diagram you provided, the WAN interfaces are the connections to the internet service providers (ISPs). Unlike LAN interfaces, WAN interfaces are typically used to connect to external networks, such as the internet, rather than connecting to local devices within your own network.
VLANs (Virtual LANs) are used to logically segment a local network into separate broadcast domains. They are primarily used within your own network infrastructure to isolate traffic and improve network efficiency. VLANs are usually implemented on LAN interfaces of switches and routers.
Diference between creating VLANs on switches and on WAN interfaces ?
--VLANs on switches are used to logically separate devices within your internal network.
--They allow you to group devices into different broadcast domains, providing security and performance benefits.
--VLANs are created on Ethernet interfaces of switches to segregate traffic from different departments, applications, or security zones.
--VLANs on switches are used for internal network management and organization.
Creating VLANs on WAN Interfaces ?
--Creating VLANs on WAN interfaces is not a common practice because WAN interfaces are usually dedicated to connecting to external networks like ISPs.
--ISPs usually provide a single logical connection on a WAN interface; there's generally no need to segment this connection with VLANs.
--The WAN interfaces are used to connect your local network to the wider internet. VLANs are more about segmenting your own network.
There are no dumb questions when you're learning. Feel free to ask anything you're curious about!
Best regards
5 Replies 5
Hi @ankitohc
The vlan is created on the router and the wan interface can be associated to the vlan just like the LAN interface.
 But this is not the usual. Usually,  wan interface is layer3 only and have IP address to create point to point links
M02@rt37
Hello @ankitohc,
Best regards
Thank you for the detailed explanation.
You're welcome @ankitohc
Best regards
Joseph W. Doherty
Actually, BTW, many Cisco routers (not L3 switches) do support the equivalent of a VLAN interface, a bridge interface, but it would not normally be used, for the same reason a VLAN would not join WAN interfaces (as described by M02@rt37), because WAN interfaces are generally not within the same L2 domain, which is what a VLAN (and bridge) interface provides.
