BPDU Guard and Filter with Cisco IP Phones
Phil Bradley
Level 4
Level 4
I have a question regarding implementing bpdu guard/filter on access ports in my network that also have Cisco IP phones attached and the phones have desktop PC's plugged into them. Does a Cisco IP phone participate in STP and send/receive bpdu's? I would like to implement BPDU guard or filter on the access ports going to the client phones/pc's. If I implement BPDU filter at the global level then this only applies to ports that are in the portfast state and if it receives a BPDU on this port then it takes it out of portfast, correct? I assume if I plugged a switch into an access port with BPDU filter at the global level then it would kick it out of portfast and then process/participate in STP? Thanks!
5 Replies 5
rasmus.elmholt
Level 7
Level 7
Hi Phil
If BPDU Filter is configured on the global level using the spanning-tree portfast bpdufilter
default global configuration command, the BPDU Filter applies only to PortFast-enabled ports. When these ports come up, they will send up to 11 BPDUs and then stop sending further BPDUs. If the BPDU Filter-configured interface receives a BPDU at any time, the BPDU Filter and PortFast will be deactivated on that port and it will become a normal spanning tree interface. As a result, a globally configured BPDU Filter does not prevent ports from receiving and processing BPDUs; it only attempts to stop sending BPDUs on ports where most probably, there is no device attached that would be interested in processing them.
Thanks for the info. I am going to enable filter at the global level and then enable guard at the interface level so that I get alerted if a switch is plugged in. I was just concerned that if a cisco phone was plugged in on a guard interface that it would shut the port down. Even though the phone is technically a switch, I assume it doesn't participate in spanning tree. After all with only two ports it would be impossible to create a loop unless you plugged another switch into the desktop port?
I don't recall the phones sending out BPDUs.
Would normally enable BPDUGuard on all access ports with phones and without.
Don't forget to rate replies as helpful.
nixpengu1n
Cisco IP Phones have built-in switch but it acts not like a normal switch - it determines requirements for voice vlan through CDP and builds a trunk without any BPDUs. So you can issue this config on access port of your switch:
spanning-tree bpduguard enable
switchport voice vlan X
switchport access vlan Y
auto qos voip cisco-phone
But do not forget to enable CDP on this interface or globally.
What if a cisco IP Phone is physically connected with both its ports (switch and PC) "daisy chained" to the same switch?
Had a person connect both PC and switch ports on cisco IP Phone to the two wall ports, creating a loop.
