Vlan overlapping
I need to enter the config below on one of our core switches
Interface Vlan 12
IP address 10.208.75.69 255.255.255.192
ip vrf forwarding WAN
When I enter this I get the message that % 10.208.75.64 overlaps with Vlan151
Configuration of Vlan 151 is
interface Vlan151
ip address 10.208.75.65 255.255.255.252
Any assistance would be appreciated.
6 Replies 6
Seb Rupik
Hi there,
The VLAN 151 subnet 10.208.75.64 /30 occupies he same subnet as VLAN12 10.208.75.64 /26 .
Layer3 interfaces in the same VRF cannot share subnets. I suggest you adjust the VLAN12 subnet ID and mask, ie make it contiguous:
10.208.75.72 /30
...but if you need a /26 then the next usable subnet ID would be:
10.208.75.128 /26
cheers,
Seb.
Thanks Seb
ssambourg
Level 3
Level 3
to make the routing decision process for the connected subnet, you can't have two interfaces in the same subnet (partially / totaly).
10.208.75.69 255.255.255.192 start from 10.208.64.0 (network address) and finish at 10.208.127.255 (broadcast).
10.208.75.65 255.255.255.252 start from 10.208.75.64 (network address) and finish to 10.208.75.67 (broadcast).
Vlan 151 network adress is included in your vlan 12 network adress.
You need to review your addressing scheme.
Thanks ssambourg
luis_cordova
Hi [email protected] ,
The network you are trying to enter overlaps with the other:
Vlan12 = 10.208.75.69 255.255.255.192
Network= 10.208.75.64
First IP= 10.208.75.65
Last IP= 10.208.75.126
Broadcast= 10.208.75.127
As you can see, network vlan12  is in conflict with  the network of vlan 151.
thanks luis
