vlan question
anitachoi3
I config two CAT 3750 switches, one is on 32/F; other is on 8/F. there are two in-house fibers to be connected to each other. router is on 32/F.
I would like 192.168.16.0, 192.168.17.0 traffic via fiber A
172.16.16.0, 172.16.17.0 traffic via fiber B
It seems that my config is not working.
1. How to config the trunks to run different traffic?
2. any problem if I do not config VLAN1 on switch?
rgds
32/F segment
192.168.16.0/24
192.168.17.0/24
192.168.18.0/24
192.168.19.0/24
172.16.16.0/24
172.16.17.0/24
172.16.18.0/24
10/F segment
192.168.16.0/24
192.168.17.0/24
192.168.24.0/24
192.168.25.0/24
172.16.16.0/24
172.16.17.0/24
! R1
interface GigabitEthernet0/0
no ip address
interface GigabitEthernet0/0.1
encapsulation dot1Q 1 native
ip address 172.16.1.1 255.255.255.252
ip nat inside
interface GigabitEthernet0/0.2
encapsulation dot1Q 2
ip address 192.168.16.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/0.3
encapsulation dot1Q 3
ip address 192.168.17.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/0.12
encapsulation dot1Q 12
ip address 172.16.16.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/0.13
encapsulation dot1Q 13
ip address 172.16.17.1 255.255.255.0
ip nat inside
Interface FastEthernet1
ip address 209.x.x.x 255.255.255.252
ip nat outside
ip nat pool office 209.x.x.x 209.x.x.x netmask 255.255.255.252
ip nat inside source 10 interface FastEthernet1 overload
access-list 10 permit 172.16.0.0 0.0.0.255
access-list 10 permit 192.168.16.0 0.0.0.255
access-list 10 permit 192.168.17.0 0.0.0.255
access-list 10 permit 172.16.16.0 0.0.0.255
access-list 10 permit 172.16.17.0 0.0.0.255
! switch
interface gigabitethernet2/0/1
description Trunk to router A GE 0/0, fiber A
switchport mode trunk
interface gigabitethernet2/0/2
description Trunk to router A GE 0/1, fiber B
interface FastEthernet0/1
switchport access vlan 2
interface FastEthernet0/2
switchport access vlan 3
interface FastEthernet0/8
switchport access vlan 12
interface FastEthernet0/9
switchport access vlan 13
Hi Anita,
You should move the 172.16.x.x subnets (vlans 12 and 13) from GE0/0 to GE0/1.
This way the traffic of 172.16.x.x subnets will go on fiber B.
interface GigabitEthernet0/1
no ip address
interface GigabitEthernet0/1.12
ip nat inside
interface GigabitEthernet0/1.13
ip nat inside
Try this configuration.
If it doesn't work, please send me more info about your present configuration: full running-configs, drawing about physical connections, etc.
Cheers:
Istvan
Istvan_Rabai
Level 7
Level 7
Hi Anita,
It seems to me that GE 2/0/2 of your switch is connected to GE 0/1, fiber B, on router R1 but I don't see any layer 3 config on GE 0/1.
Cheers:
Istvan
how to config it? I do not have any idea? please advise
rdgs
Hi Anita,
no ip address
ip nat inside
ip nat inside
Cheers:
Istvan
