vlan routing same switch 3550-12T
MHSITServices
I'm having some problems setting up vlans to talk to each other on a 3550-12T switch.
Its quite a simple setup I have, but I need to split my network up.
Currently I have a network of 192.168.25.0 255.255.255.0
I want to create a new vlan network of 192.168.30.0 255.255.255.0
So I have configured my vlan1 (default vlan) to have an ip of 192.168.25.250 for getting to the management page
I have created a vlan2 of 192.168.30.1 255.255.255.0
I have a port 10 linked to one of my 3560G's
In port 9 which is on vlan2 I have my pc plugged in with a static ip of 192.168.30.50
from the router I can ping any device on 192.168.25.x
I can not ping 192.168.30.1 (which is my vlan2) nor can i ping the PC
I have enabled ip routing
But I dont have a default route, this is becase we don't have a router on the network,
Any suggestions, I'm not a cisco person by trade and I'm a little out of my comfort zone
18 Replies 18
Post Show run of boht Switches...
Jawad
Looks like G0/10 isnt in a switchport mode.
Can you try?
sh int gig0/10 switchport
conf t
int gig0/10
switchport
res
Paul
Please don't forget to rate this post if it has been helpful.
Kind Regards
Paul
COnfig Below with command keyed in
show run
Building configuration...
Current configuration : 1312 bytes
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname Switch
ip subnet-zero
ip routing
no ip finger
interface GigabitEthernet0/1
no ip address
snmp trap link-status
--More--                           interface GigabitEthernet0/2
no ip address
interface GigabitEthernet0/3
no ip address
interface GigabitEthernet0/4
no ip address
interface GigabitEthernet0/5
no ip address
interface GigabitEthernet0/6
no ip address
interface GigabitEthernet0/7
no ip address
--More--                           !
interface GigabitEthernet0/8
no ip address
interface GigabitEthernet0/9
switchport access vlan 2
no ip address
interface GigabitEthernet0/10
no ip address
interface GigabitEthernet0/11
no ip address
interface GigabitEthernet0/12
no ip address
interface Vlan1
--More--                            ip address 192.168.25.250 255.255.255.0
interface Vlan2
ip address 192.168.30.1 255.255.255.0
router rip
network 192.168.0.0
ip classless
ip http server
line con 0
transport input none
line vty 0 4
login
line vty 5 15
login
end
Switch# sh int gig0/10 switchport
Switchport: Enabled
Administrative Mode: dynamic desirable
Operational Mode: down
Administrative Trunking Encapsulation: negotiate
Negotiation of Trunking: On
Access Mode VLAN: 1 (default)
Trunking Native Mode VLAN: 1 (default)
Trunking VLANs Enabled: ALL
Pruning VLANs Enabled: 2-1001
Protected: false
Unknown unicast blocked: disabled
Unknown multicast blocked: disabled
Broadcast Suppression Level
The switch it is connected to config is below
MH-GB-SWITCH-2#show run
Current configuration : 7233 bytes
version 12.2
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname MH-GB-SWITCH-2
logging buffered 51200 informational
logging console critical
logging monitor critical
enable secret 5 $1$Ml3U$bFlPKQNfnCKsnsOkPOFGF0
username admin privilege 15 password 7 044902100A335F470D1C5559
aaa new-model
aaa authentication login default local
aaa authorization console
aaa authorization exec default local
aaa session-id common
clock timezone GMT 0
clock summer-time BST recurring last Sun Mar 1:00 last Sun Oct 2:00
system mtu routing 1500
ip subnet-zero
ip tcp synwait-time 10
no ip domain-lookup
port-channel load-balance src-ip
no file verify auto
spanning-tree mode rapid-pvst
spanning-tree portfast default
spanning-tree uplinkfast
spanning-tree vlan 1-4094 priority 28672
vlan internal allocation policy ascending
interface Null0
no ip unreachables
switchport mode access
mls qos trust cos
mls qos trust cos
mls qos trust cos
mls qos trust cos
mls qos trust cos
mls qos trust cos
mls qos trust cos
mls qos trust cos
mls qos trust cos
mls qos trust cos
mls qos trust cos
mls qos trust cos
interface GigabitEthernet0/13
mls qos trust cos
interface GigabitEthernet0/14
mls qos trust cos
interface GigabitEthernet0/15
mls qos trust cos
interface GigabitEthernet0/16
mls qos trust cos
interface GigabitEthernet0/17
mls qos trust cos
interface GigabitEthernet0/18
mls qos trust cos
interface GigabitEthernet0/19
mls qos trust cos
interface GigabitEthernet0/20
mls qos trust cos
interface GigabitEthernet0/21
mls qos trust cos
interface GigabitEthernet0/22
mls qos trust cos
interface GigabitEthernet0/23
mls qos trust cos
interface GigabitEthernet0/24
mls qos trust cos
interface GigabitEthernet0/25
mls qos trust cos
interface GigabitEthernet0/26
mls qos trust cos
interface GigabitEthernet0/27
mls qos trust cos
interface GigabitEthernet0/28
mls qos trust cos
interface GigabitEthernet0/29
mls qos trust cos
interface GigabitEthernet0/30
mls qos trust cos
interface GigabitEthernet0/31
mls qos trust cos
interface GigabitEthernet0/32
mls qos trust cos
interface GigabitEthernet0/33
mls qos trust cos
interface GigabitEthernet0/34
mls qos trust cos
interface GigabitEthernet0/35
mls qos trust cos
interface GigabitEthernet0/36
mls qos trust cos
interface GigabitEthernet0/37
mls qos trust cos
interface GigabitEthernet0/38
mls qos trust cos
interface GigabitEthernet0/39
mls qos trust cos
interface GigabitEthernet0/40
mls qos trust cos
interface GigabitEthernet0/41
mls qos trust cos
interface GigabitEthernet0/42
mls qos trust cos
interface GigabitEthernet0/43
mls qos trust cos
interface GigabitEthernet0/44
mls qos trust cos
interface GigabitEthernet0/45
mls qos trust cos
interface GigabitEthernet0/46
mls qos trust cos
interface GigabitEthernet0/47
mls qos trust cos
interface GigabitEthernet0/48
mls qos trust cos
interface GigabitEthernet0/49
mls qos trust cos
interface GigabitEthernet0/50
mls qos trust cos
interface GigabitEthernet0/51
mls qos trust cos
interface GigabitEthernet0/52
mls qos trust cos
interface Vlan1
ip address 192.168.25.51 255.255.255.0
no ip redirects
ip classless
ip http server
ip http authentication local
logging trap critical
snmp-server community riverside0. RW
snmp-server packetsize 2048
snmp-server location M
snmp-server contact M
snmp-server chassis-id M
radius-server source-ports 1645-1646
control-plane
banner motd ^C
|          This system is the property of....        |
|              WARNING: Authorized access only!             |
| Disconnect immediately if you are not an authorized user! |
^C
line con 0
exec-timeout 0 0
password 7 0316521D031D32454A0C494B
line vty 0 4
exec-timeout 0 0
password 7 01010F125E19150625491E47
length 0
line vty 5 15
exec-timeout 0 0
password 7 1500021A0138382D2C36656C
end
MH-GB-SWITCH-2#
