vlan routing same switch 3550-12T
MHSITServices
I'm having some problems setting up vlans to talk to each other on a 3550-12T switch.
Its quite a simple setup I have, but I need to split my network up.
Currently I have a network of 192.168.25.0 255.255.255.0
I want to create a new vlan network of 192.168.30.0 255.255.255.0
So I have configured my vlan1 (default vlan) to have an ip of 192.168.25.250 for getting to the management page
I have created a vlan2 of 192.168.30.1 255.255.255.0
I have a port 10 linked to one of my 3560G's
In port 9 which is on vlan2 I have my pc plugged in with a static ip of 192.168.30.50
from the router I can ping any device on 192.168.25.x
I can not ping 192.168.30.1 (which is my vlan2) nor can i ping the PC
I have enabled ip routing
But I dont have a default route, this is becase we don't have a router on the network,
Any suggestions, I'm not a cisco person by trade and I'm a little out of my comfort zone
18 Replies 18
Reza Sharifi
Is 3550-12T connected to 3560G?
when you say "my pc plugged in with a static ip of 192.168.30.50"
so, is your pc onnected to the 3560G or 3550-12T?
What device is the router?
Is that a separate device or one of the switches?
Perhaps, you can post simple diagram on how everything is connected together including your PC to help us help you.
my pc is plugged into the 3550
I do not have a router, we have a box of tricks that links are network.
I'm only interested currently on getting the 192.168.30.x network to speak to the 192.168.25.x network
So, both vlans are on the same switch right?
Do you have both SVIs for vlan 1 and 2
try these and post the output:
sh run int vlan 1
and
sh run int vlan 2
then see if the interfcese are in up and up mode
sh ip int bri vlan 1
and
sh ip int bri vlan 2
also
sh vlan
here it is,
interface Vlan2
ip address 192.168.30.1 255.255.255.0
end
Switch#show ip int bri vlan 1
Interface                  IP-Address      OK? Method Status                Prot
ocol
Vlan1                      192.168.25.250  YES manual up                    up
Switch#
Switch#show ip int bri vlan 2
ocol
Vlan2                      192.168.30.1    YES manual up                    up
Switch#
VLAN Name                             Status    Ports
1    default                          active    Gi0/1, Gi0/2, Gi0/3, Gi0/4
                                                Gi0/5, Gi0/6, Gi0/7, Gi0/8
                                                Gi0/10, Gi0/11, Gi0/12
2    2                                active    Gi0/9
3    VLAN0003                         active
10   VLAN0010                         active
1002 fddi-default                     active
1003 token-ring-default               active
1004 fddinet-default                  active
1005 trnet-default                    active
VLAN Type  SAID       MTU   Parent RingNo BridgeNo Stp  BrdgMode Trans1 Trans2
1    enet  100001     1500  -      -      -        -    -        1002   1003
2    enet  10000      1500  -      -      -        -    -        0      0
3    enet  100003     1500  -      -      -        -    -        0      0
10   enet  100010     1500  -      -      -        -    -        0      0
1002 fddi  101002     1500  -      -      -        -    -        1      1003
1003 tr    101003     1500  1005   0      -        -    srb      1      1002
1004 fdnet 101004     1500  -      -      1        ibm  -        0      0
1005 trnet 101005     1500  -      -      1        ibm  -        0      0
Switch#
ok,
what is the IOS image you are running?
can you post sh ver
Does the PC have the correct default gateway (192.168.30.1)?
I did not have a gateway set.
This is set now.
So I can ping vlan2, I can not from my pc get out to vlan1
sh ver
IOS (tm) C3550 Software (C3550-I5Q3L2-M), Version 12.1(4)EA1d, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2001 by cisco Systems, Inc.
Compiled Fri 17-Aug-01 12:58 by antonino
Image text-base: 0x00003000, data-base: 0x005F2C0C
ROM: Bootstrap program is C3550 boot loader
Switch uptime is 1 hour, 12 minutes
System image file is "flash:c3550-i5q3l2-mz.121-4.EA1d/c3550-i5q3l2-mz.121-4.EA1d.bin"
cisco WS-C3550-12T (PowerPC) processor (revision 04) with 65526K/8192K bytes of memory.
Processor board ID FAA0538S040
Last reset from warm-reset
Bridging software.
Running Layer2/3 Switching Image
Ethernet-controller 1 has 1 Gigabit  Ethernet/IEEE 802.3 interfaces
--More--                           Ethernet-controller 2 has 1 Gigabit  Ethernet/IEEE 802.3 interfaces
Ethernet-controller 3 has 1 Gigabit  Ethernet/IEEE 802.3 interfaces
Ethernet-controller 4 has 1 Gigabit  Ethernet/IEEE 802.3 interfaces
Ethernet-controller 5 has 1 Gigabit  Ethernet/IEEE 802.3 interfaces
Ethernet-controller 6 has 1 Gigabit  Ethernet/IEEE 802.3 interfaces
Ethernet-controller 7 has 1 Gigabit  Ethernet/IEEE 802.3 interfaces
Ethernet-controller 8 has 1 Gigabit  Ethernet/IEEE 802.3 interfaces
Ethernet-controller 9 has 1 Gigabit  Ethernet/IEEE 802.3 interfaces
Ethernet-controller 10 has 1 Gigabit  Ethernet/IEEE 802.3 interfaces
Ethernet-controller 11 has 1 Gigabit  Ethernet/IEEE 802.3 interfaces
Ethernet-controller 12 has 1 Gigabit  Ethernet/IEEE 802.3 interfaces
12 Gigabit Ethernet/IEEE 802.3 interface(s)
--More--
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:05:DD:C3:70:80
Motherboard assembly number: 73-5527-09
Power supply part number: 34-0967-01
Motherboard serial number: FAA0537HHZS
Power supply serial number: LIT050900Q6
Model revision number: 04
Model number: WS-C3550-12T
System serial number: FAA0538S040
Configuration register is 0x10F
Switch#show run
Building configuration...
Current configuration : 1251 bytes
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname Switch
ip subnet-zero
ip routing
no ip finger
interface GigabitEthernet0/1
no ip address
snmp trap link-status
--More--                           interface GigabitEthernet0/2
no ip address
interface GigabitEthernet0/3
no ip address
interface GigabitEthernet0/4
no ip address
interface GigabitEthernet0/5
no ip address
interface GigabitEthernet0/6
no ip address
interface GigabitEthernet0/7
no ip address
--More--                           !
interface GigabitEthernet0/8
no ip address
interface GigabitEthernet0/9
switchport access vlan 2
no ip address
interface GigabitEthernet0/10
no ip address
interface GigabitEthernet0/11
no ip address
interface GigabitEthernet0/12
no ip address
interface Vlan1
--More--                            ip address 192.168.25.250 255.255.255.0
interface Vlan2
ip classless
ip http server
line con 0
transport input none
line vty 5 15
Can you logon to the switch and try to
ping 192.168.30.1
and also
ping 192.168.25.250
if good try to ping the PC (30.50)
I can ping the ip's on the router
I cannot ping the PC
I can ping anything on the 192.168.25.x network from the router.
does the PC have any firewall software installed on it that maybe blocking ping?
It does.
But if we step back from that.
From the PC I can ping the switch on 192.168.30.1
From the PC I cannot ping 192.168.25.250
If I disconnect the Ethernet, and use my wi-fi , I can ping 192.168.25.250 , I then cannot ping 192.168.30.1
So try this
disable the wireless on the PC and then try to ping 25.250 using the Ethernet port
Try this
disable the wireless on the PC temporary and then try to ping 25.250 using the Ethernet port only.
Dest Host un-reachable.
I made more progress I have added onto the switch as follows
router rip
network 192.168.0.0
So from my PC I can now ping the 192.168.25.250
My next challenge is to see anything on 192.168.25.x
I'm going to guess I need to add to the connecting switch a path back somehow
