VLAN's Cisco SF200
knightcelt100
Hello, I need your help
I have some problems with VLAN's and a SF200 Switch, I have the following network structure
A Fortigate firewall that through DHCP assigns 2 networks.
The main network which is 192.168.3.0/24 and a VLAN10 which is 172.16.20.0/24.
On port 3 and 4 of the fortinet I have the SF200 and another unmanaged switch, he is SF200, I have an access point with 2 SSIDs and each of them assigned to the main network and another to VLAN10, but when I connect to the main network all goes well, but if I connect to the VLAN10 it does not assign IP.
However, if the same Access Point is connected to the other unmanaged Switch, both networks work fine.
In the SF200 I have already made all the possible configurations, put the port in general mode and disable smartpor, configure VLAN10, put the port in access mode, put the port in trunk mode and more tests, without being able to connect to the VLAN10 network , to the main one if it connects.
balaji.bandi
the port connected to fortinet what config it has ?
did you create VLAN 10 on the switch ?
BB
