vlan span between dell and cisco switch
bbb bbb
Dear Everyone,
Good day
Seeking advice on this scenario in a client environment. We are trying to establish gateway reachability from PC2 connected in Cisco 9300 but not able yield positive result. Trunks are configured on Port-channel where physical interfaces are member of. Access port is also configured for each corresponding port.
Core Switch - Gateway for VLAN 1-5 and 6-10, located in Datacenter1
Dell S5232F-ON - 10G/100G links, connected with trunk (Port-channel), located in Datacenter 2,
Dell S5248F-ON - 1G/10G links, connected with trunk (Port-channel), located in Datacenter2
Cisco 9300 - 1G/10G links, connected with trunk (Port-channel), located in Datacenter2
Configuration at Cisco 9300
Cisco9300#show lldp neighbors
Capability codes:
(R) Router, (B) Bridge, (T) Telephone, (C) DOCSIS Cable Device
(W) WLAN Access Point, (P) Repeater, (S) Station, (O) Other
Device ID Local Intf Hold-time Capability Port ID
DELL-S5248F-ON Gi1/0/46 120 P,B,R ethernet1/1/6:1
Total entries displayed: 1
Cisco9300#
Cisco9300#sh run int port-channel 120
Building configuration...
Current configuration : 168 bytes
interface Port-channel120
description Cisco 9300<>DELL S5248F-ON
switchport trunk allowed vlan 5,6-10
switchport mode trunk
end
Cisco9300#
Cisco9300#sh run int g1/0/46
Current configuration : 165 bytes
interface GigabitEthernet1/0/46
switchport trunk allowed vlan 5, 6-10
channel-group 120 mode active
end
Cisco9300#sh interfaces trunk
Port Mode Encapsulation Status Native vlan
Po120 on 802.1q trunking 1
Port Vlans allowed on trunk
Po120 5,6-10
Port Vlans allowed and active in management domain
Po120 5,6-10
Port Vlans in spanning tree forwarding state and not pruned
Po120 5,6-10
Cisco9300#
Capability codes:
Cisco9300#
Cisco9300#show run interface g1/0/8
interface GigabitEthernet1/0/8
description link to PC2
switchport access vlan 5
switchport mode access
spanning-tree portfast
end
Configuration at DELL switch S5248F-ON
DELLS5248F-ON# show running-configuration interface port-channel 150
interface port-channel150
no shutdown
switchport access vlan 95
vlt-port-channel 150
DELLS5248F-ON#
DELLS5248F-ON#
DELLS5248F-ON# show running-configuration interface ethernet 1/1/6:1
interface ethernet1/1/6:1
no shutdown
channel-group 150 mode active
no switchport
flowcontrol receive off
DELLS5248F-ON#
DELLS5248F-ON# show vlan 5
Codes: * - Default VLAN, M - Management VLAN, R - Remote Port Mirroring VLANs,
@ - Attached to Virtual Network, P - Primary, C - Community, I - Isolated,
S - VLAN-Stack VLAN
Q: A - Access (Untagged), T - Tagged
NUM Status Description Q Ports
5 Active VLAN5 T Po150
A Eth1/1/46:1
DELLS5248F-ON#
DELLS5248F-ON# show running-configuration interface ethernet 1/1/46:1
interface ethernet1/1/46:1
description link to PC1
no shutdown
DELLS5248F-ON#
DELLS5248F-ON## show lldp neighbors
Loc PortID Rem Host Name Rem Port Id Rem Chassis Id
ethernet1/1/6:1 Cisco9300 Gi1/0/46 c2:1d:80:c2:1d:80
ethernet1/1/46:1 Not Advertised 00:3f:00:00:00:83 00:3f:00:00:00:83
Looking forward to your responses. Best regards
16 Replies 16
Enes Simnica
Level 5
Level 5
hello @bbb bbb . Based on the provided information and the diagram my Cisco friend, it looks like the issue stems from a configuration mismatch on the Dell S5248F-ON uplink interface toward the Cisco 9300.
this line in the Dell config:
no switchport
This means the interface is configured as a Layer 3 routed port, not a switchport trunk carrying VLANs. As a result, even though Port-Channel150 is defined as a trunk, the physical member interface connecting to the Cisco 9300 is effectively not forwarding VLAN 5 traffic, hence why PC2 can’t reach the VLAN 5 gateway.
Meanwhile, PC1 is working fine because its access port on the Dell switch is correctly configured in VLAN 5.
also i would recommend u some configs or changes:
1. Convert the Dell interface ethernet1/1/6:1 back to a switchport so it participates in VLAN trunking:
switchport
2. After applying verify using some show commands like;: show interfaces trunk, show spann vlan 5, show vlan..
3. And test reachabillity from pC2 to the vlan 5 gateway again.......
and check this links for more help:https://www.dell.com/support/kbdoc/en-us/000122519/how-to-create-vlans-on-a-dell-networking-powerconnect-switches
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst1000/software/releases/15_2_7_e/configuration_guides/vlan/b_1527e_vlan_c1000_cg/configuring_vlan_trunks.pdf
as usual, hope its not a loong answer, and hope it helps! PEACE!
-Enes
more Cisco?!
more Gym?!
If this post solved your problem, kindly mark it as Accepted Solution. Much appreciated!
Dear Enes,
Yes I did the trunk configuration on the interface level before setting up a port-channel. Did not yield positive result either.
Best regards
@bbb bbb
Provide from your DELL the output of that command:
show port-channel summary
Thanks.
Best regards
M02@rt37
Hello @bbb bbb
On you Dell switch DELLS5248F-ON,  interface 1/1/6:1 is configured with "no switchport" command.
Try to do "switchport" command to swap this interface in pur L2 state please.
Best regards
bbb bbb
Dears,
There is no option for me to do switchport only command. please see below config
DELLS5248F-ON#show running-configuration interface ethernet 1/1/6:1
no shutdown
no switchport
DELLS5248F-ON# configure terminal
DELLS5248F-ON(config)# interface ethernet 1/1/6:1
DELLS5248F-ON(conf-if-eth1/1/6:1)# switchport
access Set access mode characteristics of the interface
mode Enter the port mode access/trunk
port-security Enable port security on this interface
trunk Configure trunking parameters on an interface
access mode port-security trunk
% Error: Ambiguous command.
regards
switchport mode ?  <<- mode word allow you to specify the port access or trunk
Dear MHM,
Please see below syntax based on the suggestion.
DELLS5248F-ON(conf-if-eth1/1/6:1)# switchport mode
access Port mode access
trunk Port mode trunk
DELLS5248F-ON(conf-if-eth1/1/6:1)# switchport mode trunk
<cr>
% Error: Configured as a lag interface
bbb bbb
Dears,
Comparing existing Trunk (Port-channel) configuration on DELL S5248F-ON switch have the same settings above.
DELLS5248F-ON# show port-channel summary
Flags: D - Down I - member up but inactive P - member up and active
U - Up (port-channel) F - Fallback Activated IND - LACP Individual
Group Port-Channel Type Protocol Member Ports
140 port-channel140 (U) Eth DYNAMIC 1/1/53(P) 1/1/54(P)
150 port-channel150 (U) Eth DYNAMIC 1/1/6:1(P)
DELLS5248F-ON# show running-configuration interface ethernet 1/1/53
interface ethernet1/1/53
description UPLINK
no shutdown
channel-group 140 mode active
no switchport
DELLS5248F-ON# show running-configuration interface ethernet 1/1/54
interface ethernet1/1/54
description UPLINK
no shutdown
no switchport
DELLS5248F-ON# show running-configuration interface port-channel 140
interface port-channel140
no shutdown
switchport access vlan 1
vlt-port-channel 140
no shutdown
DELLS5248F-ON#
Now it L2 trunk
And Port channel U (up) and port member (P)
So every thing is OK
bbb bbb
still not reachable.
What STP mode run in both side?
MHM
Dear,
Both switch running with rstp. Connectivity is established after modifying the trunk configuration on each interfaces of the switch.
Best Regards,
But sorry cisco not support rstp it support rapid PVST
Anyway glad issue is solved now
MHM
thank you and appreciated for your insight
