Vlan switch and subinterface vlan
I have an 8 port L2 switch which has 3 ports in VLAN 10 and 4 ports in VLAN 20
Port 1 of the switch is a trunk port connect to FastEthernet 0 of my Cisco router which is doing inter VLAN routing between both VLANs by using the following commands
interface FastEthernet0.10
encapsulation dot1Q 10
ip address 192.168.0.1 255.255.255.0
interface FastEthernet0.20
encapsulation dot1Q 20
ip address 10.10.0.1 255.255.0.0
The router also has 8 switch ports and I would like to assign 2 ports to VLAN 10 and another 2 to VLAN 20.
If I do the following, does it do what I want?
interface Vlan10
no ip address
interface Vlan20
no ip address
interface FastEthernet1
switchport access vlan 10
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
switchport access vlan 20
no ip address
interface FastEthernet4
no ip address
Thanks.
Jeff Van Houten
Level 11
Level 11
If fe0 can be a trunk port, then remove the sub interfaces, put in switchport mode trunk and put the ip addresses for the 2 Vlans on the svis.
Jeff Van Houten
Level 11
Level 11
You need to list the model numbers of the equipment and the software versions. There are different answers depending on those factors, but if you're running an older router like I think you are, you're most likely going to have to cross-cable the 2 switches and get rid of the svis on the router.
The router is an 1801 running IOS 15.1. It has 9 switch ports with FE0 capable of being used as a trunk port.
The switch is a TP Link SG3210 layer 2 managed switch.
Jeff Van Houten
Level 11
Level 11
Thanks!
I cannot use FE0 as a trunk port only divide it into subinterfaces, but you've helped me get the SVI vlans working by using one of the switchports (fa1 - 8 ) as a trunk.
This is how I originally tried to get intervlan routing working but couldn't and found the subinterface method.
Here's a test solution in case anyone else has this problem
On the layer 2 switch, Ive plugged a NAS storage device (192.168.200.2) into port 7 and set that port as a GENERAL port with a PVID of 50 (Port VLAN ID also known as VLAN ID).
Port 8 is set up as a TRUNK port, trunking PVID 50 and this connects to FE8 on the Cisco which is the corresponding trunk port.
On the Cisco, I have the following config...
vlan 50
name TEST
interface FastEthernet8
switchport trunk native vlan 50
no ip address
interface Vlan50
description TEST
ip address 192.168.200.1 255.255.255.0
This works great.
One last question, why would someone use subinterfaces or the above method of inter vlan routing?
