Using Flexstack Cables on more than 4 switches
Andrew Clark
I am using 5 Cisco 2960-X switches and want to make sure i am connecting the flex stack cables correctly. Everything i can find only shows a 2, 3, or 4 stack. I'm assuming that the 5 stack is just like the four stack when using the 5m cable to connect the 5th and the 1st, but i just need to make sure.
Switch 1 port 1 to port 2 on switch 2
Switch 1 port 2 to port 1 on switch 5
and all the switches in between are 1 to 2
Leo Laohoo
Duplicate posts.
