VLAN Traffic issue between two Switches
Mike36
Hello Everyone,
I have a Firewall and 2 Cisco Switches.
  1. Opnsense Firewall (FW)
  2. Cisco CBS350-8FP-E-2G (SW1)
  3. Cisco CBS250-24T-4G (SW2)
The current topology is as follow.
Opnsense Firewall (FW)--->Cisco CBS350-8FP-E-2G (SW1)
  • All 4 VLANs are configured on the Firewall.
  • The trunk between the Opnsense Firewall (FW) and the Cisco CBS350-8FP-E-2G (SW1) works properly between both devices.
  • DHCP per VLAN are also provided by the Firewall
  • On the Cisco CBS350-8FP-E-2G (SW1) I’m able to assign VLAN to ports and I get the appropriate IP address and able to ping appropriate gateways.
I would like to add the CBS250-24T-4G (SW2) behind the Cisco CBS350-8FP-E-2G (SW1) and have all 4 VLANs propagate to CBS250-24T-4G (SW2). As follow.
Opnsense Firewall (FW)--->Cisco CBS350-8FP-E-2G (SW1)--> CBS250-24T-4G (SW2)
The issue that I’m having is a computer assigned any VLAN on the CBS250-24T-4G (SW2) are not getting ip address for the DHCP. I’ve tried via SFPs and copper.
Here is the configuration from both switches.
interface vlan 1
 ip address 192.168.1.2 255.255.255.0
 no ip address dhcp
interface vlan 165
 name Red
interface vlan 110
 name Blue
interface vlan 240
 name Green
interface vlan 301
 name Yellow
interface GigabitEthernet10
 switchport mode trunk
 switchport trunk allowed vlan 165,110,240,301
CISCO CBS250-24T-4G (SW2)
interface vlan 1
 ip address 192.168.1.4 255.255.255.0
 no ip address dhcp
interface vlan 165
 name Red
interface vlan 110
 name Blue
interface vlan 240
 name Green
interface vlan 301
 name Yellow
interface GigabitEthernet24
I would appreciate some help
Thank you
6 Replies 6
balaji.bandi
how is your configuraiton of the port connected Opensese FW - can you post that config.
if the switches actiong Layer 2 then that should work - its bizzar , by the way what is the DHCP Server or opensese Server IP ?
try adding VLAN 1 also in the allowed list  - on both the side trunks.(not required for testing).
switchport trunk allowed vlan 1,165,110,240,301
BB
the ports configuration on the OPNSense FW is done via the GUI but the trunk between the firewall and the SW1 works perfectly.
and the DHCP is done by the OPNSense FW.
by adding VLAN 1 on both side trunks, I now received a ip adresse from vlan but not from any other vlans.
now i'm puzzled...
Glad that all working now - i was also thinking  STP priorities - SW1 should be always STP root for all VLAN to work.
check some reference :
https://www.cisco.com/c/en/us/td/docs/switches/lan/csbms/CBS_250_350/CLI/cbs-250-cli/spanning-tree-commands.html
BB
If the FW work as L2 FW then you need only allow traffic between to side udp 67/68
That it
MHM
thanks for reply
the firewall works as a L3 FW
Mike36
I did some more testing, I've allowed all VLAN in the trunk configurations on both sides and I was able to received IP addresse from all VLAN on SW2
I've then changed the trunk configuration on both side to only allow VLAN 165,110,240,301 and everything works now
I'm even more puzzled but It works now
thanks for all your help
