01-21-2024 05:20 AM
Solved! Go to Solution.
01-31-2024 07:16 AM
I finally got it working... two problems I identified:
1. Both stacks had the same STP priority which lead to a short network outage at the beginning of each connection try
2. I used the wrong cables. The SFPs are for multi mode - I used single mode cables. Big mistake, but it happend...
Thanks to all for their help! I really appreciate it.
01-21-2024 05:59 AM
Hello @seb1303
Do you check on both sides of the VLAN trunk interface ? Verify that the interface settings (speed, duplex, VLAN configuration) match on both ends. A mismatch in configuration could lead to link instability.
01-27-2024 08:02 AM
These are the same on both sides.
01-21-2024 06:14 AM
The only think here is are you config same STP mode for both stack virtual SW?
Did you check STP ?
Did you see any log about stp?
MHM
01-21-2024 07:03 AM
What IOS XE code running both SVL - what is the Domain ID used on both the SVL (is this same ?)
check when you interconnect 2 SVL domain Id should be different - there are some Layer 2 issue around.
After enabling one side get the VLAN trunk inferface up my whole network is not working for a few seconds until the link of the VLAN trunk interface goes down again.
we also need more information your spanning-tree information - how other 3rd party device participated in Layer 2 command, what you see the logs on both SVL ?
=====️ Preenayamo Vasudevam ️=====
01-27-2024 07:31 AM - edited 01-27-2024 08:05 AM
At the beginning both had the same domain id. I changed it. But the problems are still the same.
STP on HP infrastructure is disabled.
01-27-2024 07:37 AM
Change domain-id and first time you use same ! Here you need to stop
Can I see show spanning tree in both pairs before you interconnect via trunk?
What issue I think
Domain-id use to build virtual mac for both SW this vMAC use in PO and for STP if you use same domain-id then both pairs use same vMAC and this make stp block the trunk.
Check show spanning tree see the bridge id is it same or not
If it same then you need to reboot one pair to make it select new vMAC for new different domain-id
MHM
01-27-2024 08:02 AM
I rebooted the SVL after changing the domain ID.
# SVL #1
# show spanning-tree
VLAN0001
Spanning tree enabled protocol rstp
Root ID Priority 32769
Address 3c8b.7f57.b2e0
This bridge is the root
Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec
Bridge ID Priority 32769 (priority 32768 sys-id-ext 1)
Aging Time 300 sec
Interface Role Sts Cost Prio.Nbr Type
Twe1/0/5 Desg FWD 2000 128.197 P2p
Twe1/0/7 Desg FWD 2000 128.199 P2p
Twe2/0/5 Desg FWD 2000 128.389 P2p
Twe2/0/7 Desg FWD 2000 128.391 P2p
Po2 Desg FWD 1000 128.2090 P2p
Po3 Desg FWD 1000 128.2091 P2p
VLAN0002
Root ID Priority 32770
Bridge ID Priority 32770 (priority 32768 sys-id-ext 2)
Aging Time 300 sec
VLAN0010
Root ID Priority 32778
Bridge ID Priority 32778 (priority 32768 sys-id-ext 10)
Aging Time 300 sec
Twe1/0/6 Desg FWD 2000 128.198 P2p
Twe1/0/8 Desg FWD 2000 128.200 P2p
VLAN0020
Root ID Priority 32788
Bridge ID Priority 32788 (priority 32768 sys-id-ext 20)
Aging Time 300 sec
VLAN0021
Root ID Priority 32789
Bridge ID Priority 32789 (priority 32768 sys-id-ext 21)
Aging Time 300 sec
VLAN0022
Root ID Priority 32790
Bridge ID Priority 32790 (priority 32768 sys-id-ext 22)
Aging Time 300 sec
VLAN0023
Root ID Priority 32791
Bridge ID Priority 32791 (priority 32768 sys-id-ext 23)
Aging Time 300 sec
VLAN0026
Root ID Priority 32794
Bridge ID Priority 32794 (priority 32768 sys-id-ext 26)
Aging Time 300 sec
VLAN0030
Root ID Priority 32798
Bridge ID Priority 32798 (priority 32768 sys-id-ext 30)
Aging Time 300 sec
VLAN0040
Root ID Priority 32808
Bridge ID Priority 32808 (priority 32768 sys-id-ext 40)
Aging Time 300 sec
VLAN0080
Root ID Priority 32848
Bridge ID Priority 32848 (priority 32768 sys-id-ext 80)
Aging Time 300 sec
VLAN0090
Root ID Priority 32858
Bridge ID Priority 32858 (priority 32768 sys-id-ext 90)
Aging Time 300 sec
VLAN0099
Root ID Priority 32867
Bridge ID Priority 32867 (priority 32768 sys-id-ext 99)
Aging Time 300 sec
VLAN0101
Root ID Priority 32869
Bridge ID Priority 32869 (priority 32768 sys-id-ext 101)
Aging Time 300 sec
VLAN0102
Root ID Priority 32870
Bridge ID Priority 32870 (priority 32768 sys-id-ext 102)
Aging Time 300 sec
VLAN0111
Root ID Priority 32879
Bridge ID Priority 32879 (priority 32768 sys-id-ext 111)
Aging Time 300 sec
VLAN0112
Root ID Priority 32880
Bridge ID Priority 32880 (priority 32768 sys-id-ext 112)
Aging Time 300 sec
VLAN0113
Root ID Priority 32881
Bridge ID Priority 32881 (priority 32768 sys-id-ext 113)
Aging Time 300 sec
VLAN0114
Root ID Priority 32882
Bridge ID Priority 32882 (priority 32768 sys-id-ext 114)
Aging Time 300 sec
VLAN0131
Root ID Priority 32899
Bridge ID Priority 32899 (priority 32768 sys-id-ext 131)
Aging Time 300 sec
VLAN0200
Root ID Priority 32968
Bridge ID Priority 32968 (priority 32768 sys-id-ext 200)
Aging Time 300 sec
VLAN0500
Root ID Priority 33268
Bridge ID Priority 33268 (priority 32768 sys-id-ext 500)
Aging Time 300 sec
VLAN0721
Root ID Priority 33489
Bridge ID Priority 33489 (priority 32768 sys-id-ext 721)
Aging Time 300 sec
VLAN2190
Root ID Priority 34958
Bridge ID Priority 34958 (priority 32768 sys-id-ext 2190)
Aging Time 300 sec
VLAN2194
Root ID Priority 34962
Bridge ID Priority 34962 (priority 32768 sys-id-ext 2194)
Aging Time 300 sec
VLAN2252
Root ID Priority 35020
Bridge ID Priority 35020 (priority 32768 sys-id-ext 2252)
Aging Time 300 sec
VLAN2255
Root ID Priority 35023
Bridge ID Priority 35023 (priority 32768 sys-id-ext 2255)
Aging Time 300 sec
VLAN3801
Root ID Priority 36569
Bridge ID Priority 36569 (priority 32768 sys-id-ext 3801)
Aging Time 300 sec
VLAN3802
Root ID Priority 36570
Bridge ID Priority 36570 (priority 32768 sys-id-ext 3802)
Aging Time 300 sec
VLAN3803
Root ID Priority 36571
Bridge ID Priority 36571 (priority 32768 sys-id-ext 3803)
Aging Time 300 sec
VLAN3804
Root ID Priority 36572
Bridge ID Priority 36572 (priority 32768 sys-id-ext 3804)
Aging Time 300 sec
VLAN3805
Root ID Priority 36573
Bridge ID Priority 36573 (priority 32768 sys-id-ext 3805)
Aging Time 300 sec
VLAN3806
Root ID Priority 36574
Bridge ID Priority 36574 (priority 32768 sys-id-ext 3806)
Aging Time 300 sec
VLAN3807
Root ID Priority 36575
Bridge ID Priority 36575 (priority 32768 sys-id-ext 3807)
Aging Time 300 sec
VLAN3808
Root ID Priority 36576
Bridge ID Priority 36576 (priority 32768 sys-id-ext 3808)
Aging Time 300 sec
VLAN3809
Root ID Priority 36577
Bridge ID Priority 36577 (priority 32768 sys-id-ext 3809)
Aging Time 300 sec
VLAN3898
Root ID Priority 36666
Bridge ID Priority 36666 (priority 32768 sys-id-ext 3898)
Aging Time 300 sec
VLAN3899
Root ID Priority 36667
Bridge ID Priority 36667 (priority 32768 sys-id-ext 3899)
Aging Time 300 sec
VLAN3901
Root ID Priority 36669
Bridge ID Priority 36669 (priority 32768 sys-id-ext 3901)
Aging Time 300 sec
VLAN3902
Root ID Priority 36670
Bridge ID Priority 36670 (priority 32768 sys-id-ext 3902)
Aging Time 300 sec
VLAN4000
Root ID Priority 36768
Bridge ID Priority 36768 (priority 32768 sys-id-ext 4000)
Aging Time 300 sec
VLAN4001
Root ID Priority 36769
Bridge ID Priority 36769 (priority 32768 sys-id-ext 4001)
Aging Time 300 sec
VLAN4002
Root ID Priority 36770
Bridge ID Priority 36770 (priority 32768 sys-id-ext 4002)
Aging Time 300 sec
VLAN4003
Root ID Priority 36771
Bridge ID Priority 36771 (priority 32768 sys-id-ext 4003)
Aging Time 300 sec
VLAN4004
Root ID Priority 36772
Bridge ID Priority 36772 (priority 32768 sys-id-ext 4004)
Aging Time 300 sec
VLAN4005
Root ID Priority 36773
Bridge ID Priority 36773 (priority 32768 sys-id-ext 4005)
Aging Time 300 sec
VLAN4006
Root ID Priority 36774
Bridge ID Priority 36774 (priority 32768 sys-id-ext 4006)
Aging Time 300 sec
VLAN4007
Root ID Priority 36775
Bridge ID Priority 36775 (priority 32768 sys-id-ext 4007)
Aging Time 300 sec
VLAN4008
Root ID Priority 36776
Bridge ID Priority 36776 (priority 32768 sys-id-ext 4008)
Aging Time 300 sec
VLAN4010
Root ID Priority 36778
Bridge ID Priority 36778 (priority 32768 sys-id-ext 4010)
Aging Time 300 sec
VLAN4031
Root ID Priority 36799
Bridge ID Priority 36799 (priority 32768 sys-id-ext 4031)
Aging Time 300 sec
VLAN4041
Root ID Priority 36809
Bridge ID Priority 36809 (priority 32768 sys-id-ext 4041)
Aging Time 300 sec
VLAN4050
Root ID Priority 36818
Bridge ID Priority 36818 (priority 32768 sys-id-ext 4050)
Aging Time 300 sec
VLAN4051
Root ID Priority 36819
Bridge ID Priority 36819 (priority 32768 sys-id-ext 4051)
Aging Time 300 sec
VLAN4052
Root ID Priority 36820
Bridge ID Priority 36820 (priority 32768 sys-id-ext 4052)
Aging Time 300 sec
Po3 Desg FWD 1000 128.2091 P2p# SVL #2
No spanning tree instance exists.
01-27-2024 08:08 AM
above for upper or lower SVL pair SW?
according to your topology there are four SW making two pair, am I correct?
MHM
01-27-2024 08:22 AM
Above output is for both. See the comment "SVL #1" and "SVL #2".
SVL #1 shows the bigger output. SVL #2 only shows "No spanning tree instance exists."
01-27-2024 08:25 AM - edited 01-27-2024 08:29 AM
No spanning tree exists?
You mentioned that you disable stp for HP but I see you disable it for SVL #2
Show spanning tree summary <- share this for both SVL
MHM
01-27-2024 08:31 AM
Right, STP is disabled on the HP infrastructure. It is enabled on SVL #2 but there is currently no link on any interface so the output shows "No spanning tree instance exists.". As far as I know this is a normal behaviour. Isn't it?
(I shut down the port-channel of SVL #2 because this problem kills my whole networking...)
01-27-2024 08:43 AM
It correct if there is no port and all vlan down
Now
Switch#test platform software nif_mgr lmp member-port
Check this in all four SW
See stack MAC is same of different
MHM
01-27-2024 08:49 AM
I don't know which member-port I need to use. But see what I get when I run this:
SVL #1
# test platform software nif_mgr lmp local-platform-info
Local Platform Information:
Blueshift Version:1
Distributed Stack Domain:1
Distributed Stack Mode:1
System Model String:C9500-24Y4C
System Product ID:
System Version ID:
Stack MAC Address:3c8b:7f57:b2e0
System CMI Index:0
LMP Port LPN:0/0SVL #2
Blueshift Version:1
Distributed Stack Domain:2
System Product ID:
System Version ID:
Stack MAC Address:3c8b:7f57:30e0
System CMI Index:0
LMP Port LPN:0/0
01-27-2024 09:05 AM
The stack mac is ok it different since domain is different
Show lacp port-channel x
In both pair
Check the system mac address
MHM
