VLAN Trunking + VPT
bernard_major
I have two 3750 switch connected to eatch other.
There's a 802.1Q trunk between the two switchs. There's also VTP and Spantree activated on those switch. The two switch are in the same VTP domain, and they are server.
I added a VLAN 185 on the first 3750, and it did not reply on the second.
So I added manually in the second 3750 the VLAN 185.
I've configured an interface VLAN185 in both switchs, in the same network.
EX :
SWITCH1 : Int vlan185 ip : 10.10.1.1 255.255.255.0
SWITCH2 :Int vlan185 ip : 10.10.1.2 255.255.255.0
MY PROBLEM :
I'm not able to ping on both side anything in the vlan 185.
Tanks a lot.
Shera
Mmm. That is strange because it looks like the MD5 digest is different on the two switches. Sorry to insist, but are you sure there is not a VTP password? I have a synchronised domain, and I have the same MD5 digest on both server switches.
I presume these two switches are directly connected together via 3750-2 G1/0/25 to 3750-1 don't-know which port. Perhaps it would be useful to see the configs of the two ports connecting them together and a show cdp neighbor G1/0/25 detail.
Kevin Dorrell
Luxembourg
11 Replies 11
mohammedmahmoud
Level 11
Level 11
Hi Shera,
First we need to make sure that the trunk between the switches is operational and thus please post a "show interfaces trunk", second we need to check the VTP status and thus please post a "show vtp status".
BR,
Mohammed Mahmoud.
Here's the first 3750
3750-1-10.10.10.110#sh interfaces trunk
Port Mode Encapsulation Status Native vlan
Gi1/0/21 on 802.1q trunking 1
Gi1/0/22 on 802.1q trunking 1
Gi1/0/23 on 802.1q trunking 1
Gi1/0/24 on 802.1q trunking 1
Gi1/0/25 on 802.1q trunking 1
Port Vlans allowed on trunk
Gi1/0/21 1-4094
Gi1/0/22 1-4094
Gi1/0/23 1-4094
Gi1/0/24 1-4094
Gi1/0/25 1-4094
Port Vlans allowed and active in management domain
Gi1/0/21 1-2,8,10,16,161-162,167,185,192
Gi1/0/22 1-2,8,10,16,161-162,167,185,192
Gi1/0/23 1-2,8,10,16,161-162,167,185,192
Gi1/0/24 1-2,8,10,16,161-162,167,185,192
Gi1/0/25 1-2,8,10,16,161-162,167,185,192
Port Vlans in spanning tree forwarding state and not pruned
SSM-3750-001#sh vtp status
VTP Version : 2
Configuration Revision : 9
Maximum VLANs supported locally : 1005
Number of existing VLANs : 14
VTP Operating Mode : Server
VTP Domain Name : CHBE
VTP Pruning Mode : Disabled
VTP V2 Mode : Disabled
VTP Traps Generation : Disabled
MD5 digest : 0xBB 0x9E 0x23 0x70 0x2C 0x32 0x6E 0x05
Configuration last modified by 10.10.10.140 at 4-15-08 13:53:41
Local updater ID is 10.10.10.140 on interface Vl1 (lowest numbered VLAN interface
3750-2-10.10.10.140#sh int trunk
Gi1/0/1 auto n-802.1q trunking 1
Gi1/0/17 auto n-802.1q trunking 1
Gi1/0/24 auto n-802.1q trunking 1
Gi1/0/26 on 802.1q trunking 1
Gi1/0/28 on 802.1q trunking 1
Gi1/0/1 1-4094
Gi1/0/17 1-4094
Gi1/0/24 1-4094
Gi1/0/25 1-4094
Gi1/0/26 1-4094
Gi1/0/28 1-4094
Gi1/0/1 1-2,8,10,16,161-162,167,185,192
Gi1/0/17 1-2,8,10,16,161-162,167,185,192
Gi1/0/26 1-2,8,10,16,161-162,167,185,192
Gi1/0/28 1-2,8,10,16,161-162,167,185,192
Gi1/0/24 1-2,8,10,16,192
PACS_3750-01#sh vtp status
VTP Version : 2
MD5 digest : 0x1C 0x34 0x71 0xAF 0xD5 0x1F 0xC4 0x8A
Configuration last modified by 10.10.10.110 at 4-15-08 12:46:46
Local updater ID is 10.10.10.110 on interface Vl1 (lowest numbered VLAN interface found)
Maybe this will help :
3750-2-10.10.10.140#sh spanning-tree root priority
VLAN0001 4097
VLAN0002 8194
VLAN0008 8200
VLAN0010 4106
VLAN0016 8208
VLAN0161 32768
VLAN0162 32768
VLAN0167 32768
VLAN0185 32768
VLAN0192 4288
#sh spanning-tree root port
VLAN0001 GigabitEthernet1/0/25
VLAN0002 This bridge is root
VLAN0008 This bridge is root
VLAN0010 This bridge is root
VLAN0016 This bridge is root
VLAN0161 GigabitEthernet1/0/25
VLAN0162 GigabitEthernet1/0/25
VLAN0167 GigabitEthernet1/0/25
VLAN0185 GigabitEthernet1/0/24
VLAN0192 This bridge is root
3750-1-10.10.10.110#sh spanning-tree root priority
VLAN0001 4097
VLAN0002 4098
VLAN0008 4104
VLAN0010 4106
VLAN0016 4112
VLAN0161 32768
VLAN0162 32768
VLAN0167 32768
VLAN0185 32768
VLAN0192 4288
VLAN0001 This bridge is root
VLAN0010 GigabitEthernet1/0/26
VLAN0185 GigabitEthernet1/0/25
VLAN0192 GigabitEthernet1/0/26
Sorry for the delay, can you please post a "show vtp password", "sh ip int brief" and "show ip route".
BR,
Mohammed Mahmoud.
Shera,
I've to go for now, to guide you in the logical directions, please check the VTP password on both switches, please make sure that the SVI interfaces are up/up and that ip routing is enabled.
BR,
Mohammed Mahmoud.
a "show vtp counters" would be helpful, too.
hi,
Here it goes with VTP counters
3750#sh vtp counters
VTP statistics:
Summary advertisements received : 1013
Subset advertisements received : 11
Request advertisements received : 0
Summary advertisements transmitted : 971
Subset advertisements transmitted : 11
Request advertisements transmitted : 2
Number of config revision errors : 0
Number of config digest errors : 0
Number of V1 summary errors : 0
the other switch
3750-01#sh vtp counters
VTP statistics:
Summary advertisements received : 986
Subset advertisements received : 12
Request advertisements received : 2
Summary advertisements transmitted : 1027
Subset advertisements transmitted : 14
Request advertisements transmitted : 1
My collegue made an error with the sh VTP counters.
So those are the good one.
110 -3750-01#sh vtp counter
VTP statistics:
Summary advertisements received : 232553
Request advertisements received : 88268
Summary advertisements transmitted : 407709
Subset advertisements transmitted : 88258
Request advertisements transmitted : 0
Number of config revision errors : 12906
VTP pruning statistics:
Trunk Join Transmitted Join Received Summary advts received from
non-pruning-capable device
Gi1/0/1 0 0 0
Gi1/0/17 0 0 0
Gi1/0/24 0 0 0
Gi1/0/25 0 0 0
Gi1/0/26 0 0 0
Gi1/0/28 0 0 0
140 -3750-001#sh vtp counters
VTP statistics:
Summary advertisements received : 703927
Request advertisements received : 352310
Summary advertisements transmitted : 1406744
Subset advertisements transmitted : 352321
Number of config revision errors : 176247
Gi1/0/21 0 0 0
Gi1/0/22 0 0 0
Gi1/0/23 0 0 0
Gi1/0/24 0 0 0
Gi1/0/25 0 0 0
hello,
VTP password are not set on either switch
Kevin Dorrell
Luxembourg
Thanks a lot to everyone.
Using the command show cdp neighbour, we find that an other switch is use a relay between the two previous one and that switch was not in the same vtp domain and did not had all vlans that we need.
