VLAN Trunking
tyagi.vineet
I am having Cisco 3560 connected with Extreme (Summit-200-48) throgh trunk port but no communication between them. What could be the issue,not able to understand any idea please help me out.
Vineet
6 Replies 6
SOL10
Level 5
Level 5
can you post config? when you say no communication, what have you tried so far?
maybe thre is an encaspulation mismatch?
as mentioned by solpandor
see encapsulation on your cisco id it ISL or 8021Q.
ISL is cisco Proprietary whereas 8021Q is standard based.
Check on ur other switch also
scootertgm
Level 3
Level 3
Also make sure both sides are set to trunk.
at both end I am using dot1q encapsulation and trunking port is also up.
can u post ur config for both switches and if u r trying to ping what address are u using.
oszamora
Community Member
on the Cisco switch do the command
show interface trunk
verify the interface you used says "trunking" if not check if the port is up/up doing a show interfaces
Did you notice any log messages regarding the port in question or trunking?
