Vlan trunking
andyrintoul
Community Member
Does a 2900XL switch support both ISL & 802.1q trunking or like the 2950 just 802.1q????
4 Accepted Solutions
mahmoodmkl
Level 11
Level 11
it only supports dot1q
Mahmood
mohammedmahmoud
Level 11
Level 11
According to this document, Inter-Switch Link (ISL) trunking is supported on the 2900XL since Cisco IOS Release 11.2(8)SA4 (Enterprise Edition Software):
http://www.cisco.com/en/US/tech/tk389/tk390/technologies_tech_note09186a008017f86a.shtml#subtopic2h
http://www.cisco.com/univercd/cc/td/doc/product/lan/c2900xl/2935wc16/ol256212.htm
http://www.cisco.com/en/US/tech/tk389/tk390/technologies_configuration_example09186a00800a875b.shtml
NOTE: The Catalyst 2940 and 2950/2955 series switches do not support ISL encapsulation.
HTH, please rate if it does help,
Mohammed Mahmoud.
ankbhasi
The original 2900XL, or 4MB version does not support trunking at all.
5 Replies 5
mahmoodmkl
Level 11
Level 11
Mahmood
mohammedmahmoud
Level 11
Level 11
Mohammed Mahmoud.
Sorry guy's i thought he is asking about 2950.
Mahmood
ankbhasi
Hi Andy,
Yes it does support both ISL as well as dot1q.
http://www.cisco.com/univercd/cc/td/doc/product/lan/c2900xl/c2900sa4/sa4sc/masctrnk.htm
Ankur
