VLAN With secondary IP address and it’s HSRP configuration.
Switch-1
interface Vlan200
ip address 10.X.X.1 255.255.254.0 secondary
ip address 192.X.X.1 255.255.255.0
standby 200 ip 192.X.X.7
standby 200 priority 110
standby 200 preempt
standby 66 ip 10.X.X.7
standby 66 priority 95
standby 66 preempt
Switch-2
 interface Vlan200
ip address 10.X.X.4 255.255.254.0 secondary
ip address 192.X.X.2 255.255.255.0
standby 200 priority 95
standby 200 preempt
standby 66 priority 110
standby 66 preempt
is the above HSRP configuration correct.
2 Accepted Solutions
Hi again Veera,
The config looks correct. You will have Switch -1 as the HSRP active for primary ip subnet and Switch-2 as the active router for Secondary subnet with the above config.
Please let me know if you have any questions.
Hope this helps.
PS : Kindly rate all useful posts.
Madhu.
Hi Veera,
I have not tried it before, but the configuration does not seem to work since the syntax seems to wrong as you cannot type an ip address after secondary keyword. An example below.
(config-if)#standby 85 ip 10.127.1.130 secondary ?
  <cr>
But your idea seems to work with exception of the above syntax mistake. A useful post can be seen below.
https://supportforums.cisco.com/discussion/9912176/hsrp-secondary-address
Hope this helps. Please always remeber to rate all useful posts.
Madhu.
Hi again Veera,
Hope this helps.
Madhu.
Thanks Madhu.
How about this config. Just want to understand the difference.
Switch-1
interface Vlan200
standby 200 ip 192.X.X.7 secondary 10.X.X.7
standby 200 preempt
Switch-2
 interface Vlan200
standby 200 preempt
Hi Veera,
  <cr>
Madhu.
