Vlans, Native VLAN and the tagged and untagged frames
santoshbajimaya
Hello everyone,
I have one question regarding the native vlan in cisco. What is the use of native Vlan? I believe it is used for forwarding the untagged frames. But what is an untagged frame by the way because by default, everyone port in a switch is a member of at least one vlan (vlan 1). So what is the concept on untagged frame?
Thank you
Additional to Coffee's comment, frame on access ports are considered as untagged frames. The tagging process occurs over the trunk interface only, For example Switch A sends a frame for the VLAN 10 on the Switch B, the trunk on the switch A will analize the frame and add a tag saying this frame has as destination over the VLAN 10 (+ layer 2 information), once the Switch B receive the frame it will know how to send the frame to the specific destination.
The untagged frame means it does not have a Tag specifying the VLAN destination, it is not required on access ports because the switch is not sending frames to a switch instead it is sent to a computer, printer, IP camera, etc.
https://supportforums.cisco.com/t5/lan-switching-and-routing/native-vlan-tagging/td-p/2267039
https://supportforums.cisco.com/t5/lan-switching-and-routing/confused-about-frame-tagging/td-p/951219
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
6 Replies 6
Julio E. Moisa
Native vlan is a term used over a trunk interface, when the frames are sent to other switch the trunk interface verifies the frame information and put a tag in order to inform to the other end what is the vlan destination for this frame. When the trunk interface receive an untagged frame it put the frame into the native vlan and the frame is discarded, basically the native vlan could be seen as a security process. A best practice is create a new vlan (not use the Vlan 1 for this role, because this vlan is used for many purposes) to be the native vlan and use the vlan for that specific role, not assign to any port because the information received could be used for an attacker.
Hope it is useful
Hello Julio,
Thank you very much for the information. But i am still not clear on the topic. Firstly, we can all agree that VLAN 1 is also a vlan, right? So, i am little confused what an untagged frame is because by default, every port on a switch must be a member of at least 1 VLAN. Also, as per my instructor, the frames coming from default vlan is always untagged. Is it correct?, because those two are opposite to each other.
Secondly, i have consulted many videos on youtube and other material. They say that when a switch receives an untagged frame, it tags that frame with its native vlan and forwards it to those vlan ports.But you have said that those frames will be discarded after they are tagged with native vlan. So, are you trying to say, any frame tagged with native vlan is discarded on trunk link?
I have hereby attached a video for you reference (time after7 mins).
Thank You for help
As we know the VLAN has significant locally only, when a frame travels from a switch to other passing through over a trunk interface, the frame is examined and a tag is added to indicate the destination VLAN, now if we receive an untagged frame it will be sent to the native vlan and the native vlan will drop this frame. We can see this as an security process, now the best practice says, create a new vlan fro that specific role and replace the vlan 1 as native vlan on the trunks, because an attacker could deploy a vlan hoping attack.
The tagging procedure is made on the trunk interface only, rarely we will see untagged frame, blogs or websites mention that untagged frames could be associated to like voice packets.
Hello Julio,
So, can we conclude any untagged frame going through trunk link will be discarded by switch? So, what will be the case in a single switch scenario? There won't be any native vlan as there won't be any trunk link.
Also, i didn't get what an untagged frame is. As each port a switch is a member of at least default vlan, so there is nothing like untagged frame, right?
Thank you
Vlan 1 is the default vlan on cisco switches and therefore a native vlan on any trunk interface configured on the cisco switch. Vlan 1 is used for all management traffic behind the scenes like STP and CDP and therefore vlan 1 can't be suspended or shutdown. As Julio mentioned, you can change the native vlan from vlan 1 to any other vlan for security purposes as traffic associated with native vlan would be untagged. In my opinion, you shouldn't be using vlan 1 and any unused ports shouldn't be assigned to vlan 1 or native vlan ( if you have changed default native vlan 1 to any other vlan).
Note even if you change the native vlan from 1 to some other vlan that doesn't stop vlan 1 from traversing on that trunk port, because vlan 1 is continued to be used by the cisco iOS for management purposes in the background.
 In my opinion, if the native vlan has been changed to a vlan other than vlan 1 on a trunk port then a data frame that belongs to vlan 1 must be tagged or it will be dropped by the receiving switch.
