vlans on a Catalyst 4003
dukeminus
I have a catlyst 4003 switch. I need to have a few ports setup on both vlans the default and the voip.
What are the commands to have the ports be apart of both vlans and how do I setup the QOS. Thank you.
If its catos then to set ports into a Vlan its  "set vlan X  slot/port .    To trunk  its "set trunk slot/port on   dot1q" , then clear the vlans not needed off with "clear trunk slot/port  vlan x .   Old catos 4000's have very limited QOS features.  Some info  on this, http://www.cisco.com/en/US/products/hw/ ... .shtml#qa2
Another link http://www.ciscopress.com/articles/arti ... 2&seqNum=4
Report this post
5 Replies 5
subhish_p
On the interface:
switchport access vlan xxx
switchport voice vlan yyy
cant be of much help with QoS...
Cheers..
You have the POE modules? The below config on the port should work..
interface GigabitEthernet3/2
switchport mode access
auto qos voip trust
'auto qos voip trust' command will generate necessary default QOS config for the switch globally and blelow configs for interface. you can enable this command for those switch ports where you want both pc/phone.
srr-queue bandwidth share 10 10 60 20
srr-queue bandwidth shape 10 0 0 0
queue-set 2
hth
MS
Report this post
Thanks for the proper commands pretaining to the Catalyst
4003
    My only question is can the port 2/1 (fiber) port be on both vlans?  The way the switch is configured it has an uplink to the main switch via fiber   (Port 2/1)... I will need for this port to be in both vlans, if possible. I would like to thank everyone fot there help, well appreciated.
dukeminus
Hello all,
If the Catalyst 4003 can not support having ports in 2 vlans I have found a 3524 switch. Will this work? if so what would those commands be? Thanks.
