vlsm
ilnaiduccna
Hi Friends,
I want know how to utilize "VLSM subnet Calculator"
plz. find the below infor.
How to use: Enter major network address and mask in slash-format, like 192.168.1.0/24
Enter sizes (number of assignable ip addresses) of subnets to divide major network. You can specify subnetwork names instead of default.
You can change number of subnets at any time.
What is the size of subnet?
For more clarification plz. find the attached file "vlsm calculator.doc"
Naidu.
mattcalderon
Level 4
Level 4
Size is referring to how many ip addresses you want in each network to be available.
Jon Marshall
Size of subnet is how many hosts you want to be able to use in that subnet.
So if you needed 3 subnets from 192.168.1.0/24 with the following
subnet 1 will have 100 pc's
subnet 2 will have 50 pc's
subnet 3 will have 20 pc's
192.168.1.0 255.255.255.0 = 254 host addresses available ie.
192.168.1.1 -> 254, broadcast 192.168.1.255
You need 100 pc's for subnet 1 so
192.168.1.0 255.255.255.128 = 126 host addresses 192.168.1.1 -> 126, broadcast 192.168.1.127
Next you need 50 pc's
192.168.1.128 255.255.255.192 = 62 host addresses 192.168.1.129 -> 192.168.1.162, broadcast 192.168.1.163
Finally you need 20 pc's
192.168.1.192 255.255.255.224 = 30 host addresses 192.168.1.193 -> 192.168.1.222, broadcast 192.168.1.223
So the subnet sizes for your requirements are
subnet 1 100
subnet 2 50
subnet 3 20
Jon
sorry jon but i think you made a mistake on your second subnet vlsm ip addressing:
"Next you need 50 pc's
192.168.1.128 255.255.255.192 = 62 host addresses 192.168.1.129 -> 192.168.1.162, broadcast 192.168.1.163 "
if we consider we need 50 host addresses i think you meant:
192.168.1.128 255.255.255.192 = 62 host addresses 192.168.1.129 -> 192.168.1.190
broadcast 192.168.1.191
if you don't mind....
thanks.
No need to apologise - i got my maths a little bit wrong :-).
You are quite correct, thanks for correcting. Rated accordingly.
Jon
