VMPS
dhavaltandel
Level 4
Level 4
Hi All,
can i configure cisco 3560 as VMPS Server.?
- Dhaval
6 Replies 6
dhavaltandel
Level 4
Level 4
hey i got the answer, 3560 is only the VMPS client not a server.
but is still possible to create VMPS scenario, like do we have any third party or cisco software to make it done...?
- Dhaval Tandel
Hi Dhaval,
As you already got the answer 3560 cannot be conmfigured as VMPS server. There is no 3rd party tool or cisco software which can work as VMPS server. You need some higher end switch only.
Ankur
yes, even i didnt found any tool like that.
anyways thanks for taking interest.
- Dhaval Tandel
Hi Dhaval,
If your switchs support dot1x, you can use it and a radius server to configure dynamic VLAn assignment.
I have a very sucessful working version of it on one of my customers networks.
I am quite happy to tell you how to do it if you like.
Stephen
========================== http://www.rconfig.com A free, open source network device configuration management tool, customizable to your needs! - Always vote on an answer if you found it helpful
Stehen,
im very interested on this, i have similar scenario. please can you tell us ?
Hasan
You should check out the post here ...
http://forums.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Network%20Infrastructure&topic=LAN%2C%20Switching%20and%20Routing&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.1ddf269f/4#selected_message
Or search forums for "Control access to LAN via Radius"
I have given all ino here. Should you need more clarity, please let me know.
Stephen
