VMware/iSCSI SAN cisco 2960x
mergiraldo
I am planning to change the existing dell sws N2048 to the 2960x... I've heard that 2960x are not design to work with iSCSI as their performance is not enough. So can someone confirm if this is the right statement and if it is, what should be the correct series model to implement?
Reza Sharifi
2960x series switches are mainly for user facing/campus environment and not so much for data center/VMware/iSCSI. I recommend you look at the Nexus series. Nexus 9ks are pretty good. See Link below for data sheet:
https://www.cisco.com/c/en/us/products/switches/nexus-9000-series-switches/datasheet-listing.html
thank you!!... however can you be more specific telling why I should not use them.
They have small interface buffers. Often SAN servers will often have so much egress traffic packets are lost due to lack of buffers. That said, buffer (Qos) tuning can sometime (even much) mitigate the issue. (BTW, older 3560/3750 have similar issue, although they have a bit more buffer memory).
As Reza suggests, Nexus series would be a better, if not best, choice. A more enterprise/carrier grade switch often will be much better too, i.e. the Catalyst 4K or 6k families.
steven_dolan7
Hi I would presume/suggest that you have a pair of switches, for fault tolerance,
10G Ethernet is cheap and is almost minimum standard these days. Future proof, with 1-10GB
https://www.cisco.com/c/en/us/products/switches/nexus-3000-series-switches/models-comparison.html#~tab-nexus3200
https://www.arista.com/en/products/7050x-series-network-switch-datasheet
