Voice Vlan not working
rsthakur
In a single subnet total 10 2960-x switch install when I put new 2960-s series switch then in s series switch and x series(switch provide uplink to s series) IP telephone not working(It’s show verify your network connection) but data vlan working fine.
Switch Ports Model                     SW Version            SW Image
*    1 28    WS-C2960S-24PS-L          15.2(2)E9             C2960S-UNIVERSALK9-M
*    1 28    WS-C2960X-24PD-L          15.2(4)E8             C2960X-UNIVERSALK9-M
S and X series configartion:-
interface GigabitEthernet1/0/1
 switchport access vlan 30
 switchport voice vlan 5
 storm-control broadcast level 1.00
 storm-control multicast level 1.00
 spanning-tree portfast
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
 switchport mode trunk
interface GigabitEthernet1/0/24
interface GigabitEthernet1/0/25
interface GigabitEthernet1/0/26
interface GigabitEthernet1/0/27
interface GigabitEthernet1/0/28
interface Vlan1
 no ip address
 shutdown
interface Vlan30
 ip address 172.28.xxx.xx 255.255.248.0
ip default-gateway 172.28.xxx.254
ip http server
ip http secure-server
snmp-server community xxxxxxxxxxx RO
line con 0
line vty 0 4
 password 7 122A125606084F067C
 login
line vty 5 15
 login
ntp server ntp.iiserb.ac.in
ntp server 172.30.x.x
end
After a long discussion finally, I got the solution. It is a spanning tree related problem.
Thanks to everyone to provide valuable knowledge and support.
12 Replies 12
balaji.bandi
Voice VLAN not working ?  - are you not getting IP address ? or Phones are not registering ?
Where is the Layer 3 interface for switchport voice vlan 5 ?  - i do not see any config on this switch (other than VLAN assigned to Switch port)
what ports it conencted to uplink switch, can you provide uplink switch config ?
where is your DHCP Server ? is in the switch or 3rd party DHCP Server - need this information.
BB
Only show verify your network connection
NAME: "C6807-XL", DESCR: "Cisco Systems, Inc. Catalyst 6807 7-slot Chassis System"
Cisco IOS Software, s2t54 Software (s2t54-IPSERVICESK9-M), Version 15.2(1)SY1a, RELEASE SOFTWARE (fc6)
interface GigabitEthernet1/1
 description UTP For CC VLAN 30 (172.28.xxx.254/21)
 switchport
 switchport trunk allowed vlan 1,5,19,30
interface Vlan5
 description Voice VLAN
 ip address 172.25.x.xx0 255.255.0.0
ip route 0.0.0.0 0.0.0.0 172.xx.x.254
ip route 172.25.0.0 255.255.0.0 172.25.x.xxx
sh cdp n
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
                  S - Switch, H - Host, I - IGMP, r - Repeater, P - Phone,
                  D - Remote, C - CVTA, M - Two-port Mac Relay
Device ID        Local Intrfce     Holdtme    Capability  Platform  Port ID
CC_test_28.xxx.xx
                 Gig 1/0/21        153              S I   WS-C2960X Gig 1/0/22
SEP7C210D9649EE  Gig 1/0/22        155             H P M  IP Phone  Port 1
Switch configuration:-
 spanning-tree portfast edge
 switchport mode access
interface TenGigabitEthernet1/0/1
interface TenGigabitEthernet1/0/2
interface Vlan1
 no ip address
 shutdown
interface Vlan30
ip default-gateway 172.28.xxx.2xx
ip http server
snmp-server community iiserbsnmp2k RO
line con 0
line vty 0 4
 password 7 097F59480D0654105D
 login
line vty 5 15
 login
Data VLAN dhcp working on Linux dhcp server
Voice VLAN dhcp working in voice router CISCO2911/K9
If the Phone connect to Cat 6K switch is that works ?  Please post limited information - Long configuration please attach as text file easy to read.
the output not able to read correctly  if the below ports connected to uplink they are access ports
Data VLAN dhcp working on Linux dhcp server   - what is this IP address ? what port it connected on Cisco Switch of 6500?
Voice VLAN dhcp working in voice router CISCO2911/K9    what is this IP address ? what port it connected on Cisco Switch of 6500?
BB
We have a total of 350 running cisco IP Telephone on different 2 subnets. So there is no problem with the configuration of the backend router or L3 switch.
If any subnet  I was put 2960 S series switch with 2960X series switch then the problem will start(Link flapping and telephone doesn’t work).
If I replace 2960 S series switch with 2960X switch then all network work smoothly.
Problem is only with recently purchase 50 new 2960X series switch. Before this, we have 100 x series switch and 100 s series switch and all are working fine together.
We attach x series switch configuration (uplink Switch) and s series switch. The configuration is the same of all switch only interface IP change.
Before that (attach x series switch configuration) total 19 X series switch connected in this subnet and 5 telephones connected. All are working fine.
As Per my understanding you have only issue with "2960X series switch" rest all working as expected.
The config attached to post uplink switch ? is this 2960X series switch  config ? - please confirm
Can you post
show version
show macro auto device
show run interface x/x - one of the interface config, where you connect Phone flapping ?
what you see on the logs that time ?
For testing i want to default one of the interface and test and advise as below config
default interface GigabitEthernet1/0/1
no shutdown
BB
Yes
no shutdown
Try this but no result.
Remaining thing attach on word file.
switch port going down PD removed ( this may be bug i am thinking, i do not see any otehr reason)
what Model of Phone is this ? Cisco or 3rd party ?
show power inline
sh interface status error
BB
This is not a bug when I manually remove phone then this log accrue.
Cisco CP-7821, Cisco CP-3905
sh power inline
Module Available Used Remaining
(Watts) (Watts) (Watts)
1 370.0 3.3 366.7
Interface Admin Oper Power Device Class Max
(Watts)
Gi1/0/1 auto off 0.0 n/a n/a 30.0
Gi1/0/2 auto off 0.0 n/a n/a 30.0
Gi1/0/3 auto off 0.0 n/a n/a 30.0
Gi1/0/4 auto off 0.0 n/a n/a 30.0
Gi1/0/5 auto off 0.0 n/a n/a 30.0
Gi1/0/6 auto off 0.0 n/a n/a 30.0
Gi1/0/7 auto off 0.0 n/a n/a 30.0
Gi1/0/8 auto off 0.0 n/a n/a 30.0
Gi1/0/9 auto off 0.0 n/a n/a 30.0
Gi1/0/10 auto on 3.3 IP Phone 7821 1 30.0
Gi1/0/11 auto off 0.0 n/a n/a 30.0
Gi1/0/12 auto off 0.0 n/a n/a 30.0
Gi1/0/13 auto off 0.0 n/a n/a 30.0
Gi1/0/14 auto off 0.0 n/a n/a 30.0
Gi1/0/15 auto off 0.0 n/a n/a 30.0
(Watts)
Gi1/0/16 auto off 0.0 n/a n/a 30.0
Gi1/0/17 auto off 0.0 n/a n/a 30.0
Gi1/0/18 auto off 0.0 n/a n/a 30.0
Gi1/0/19 auto off 0.0 n/a n/a 30.0
Gi1/0/20 auto off 0.0 n/a n/a 30.0
Gi1/0/21 auto off 0.0 n/a n/a 30.0
Gi1/0/22 auto off 0.0 n/a n/a 30.0
Gi1/0/23 auto off 0.0 n/a n/a 30.0
Gi1/0/24 auto off 0.0 n/a n/a 30.0
sh interface gig1/0/10 status err-disabled
Port Name Status Reason Err-disabled Vlans
Gi1/0/10 connected none
suggest to run - debug ilpower ( connect the device and post the logs)
other options i suggest :
power inline port 2x-mode
shut
no shut
BB
shut
no shut
After this command phone is registered but the voice breaks frequently.
Log attach on notepad
Good to know the phone can get connected.
Can you post after full config. (current one).
voice break is different issue, we need to look, hope same issue not there other switches (thinking may be QoS on the port).
Can you also post working switch config to understand the issue.
BB
