VoIP problem
LEGETO
Visitor
Hello guys, recently I tried to build a network topology in which every PC has a VoIP phone connected.
The topology has 3 departments each department having a separate data vlan and a separate voice vlan.
everything worked fine until I connected all switches in the distribution layer.... the problem occur on the Finance switch, it does not seem to get the VoIP no matter what I try... (note: if I connect the router directly to the Finance switch then the VoIP works)
I will leave the topology attach bellow...if you want and can help please do, I will be really grateful.
Thank you in advance.
2 Accepted Solutions
you need to make sure that all Vlans actually exist on the distribution switches. I do not see Vlan 60. Manually create the Vlan on the distribution switches:
Switch#conf t
Enter configuration commands, one per line. End with CNTL/Z.
Switch(config)#vlan 60
Switch(config-vlan)#name Finance_Voice
Martin L
sounds like vlan is missing; check vlans on new switches (compare all vlans) and make sure that vlan is allowed on trunks.: show interface trunk , show vlans.
if a vlan is missing, IP phones will not be able to pass traffic to VOIP router
also, make Rapid STP works better in PT.
Regards, ML
**Please Rate All Helpful Responses **
5 Replies 5
Georg Pauwen
What are the passwords ?
Switch#conf t
It worked... thank you so much!
You are awesome guys!! all of you!
The passwords are optinet  and class.
sorry about that... I forgot about the password...
Martin L
Regards, ML
