VoIP with catalyst 2950g
wiltzlan
I'm having an issue getting a VoIP phone to work on an old 2950g (IOS 12.1(6)) switch.  I have configured the VLAN and the phone is able to get an IP address in the correct subnet.  However, the phone doesn't register.  When I plug the phone into another switch, the phone registers.  Any help is appreciated.
Here's the config from the switch (Vlan269 is the voice vlan):
Current configuration : 2369 bytes
! Last configuration change at 10:11:52 CDT Fri Jul 8 2016
! NVRAM config last updated at 10:21:10 CDT Fri Jul 8 2016
version 12.1
no service pad
service timestamps debug uptime
service timestamps log datetime
service password-encryption
service sequence-numbers
hostname 2950_VLAN_8B
enable secret 5
enable password 7
clock timezone CST -6
clock summer-time CDT recurring 2 Sun Mar 2:00 1 Sun Nov 2:00
ip subnet-zero
no ip finger
interface FastEthernet0/1
switchport access vlan 8
no cdp enable
spanning-tree portfast
interface FastEthernet0/2
description VOIP phone B113
switchport access vlan 269
switchport mode access
interface FastEthernet0/3
no cdp enable
interface FastEthernet0/4
no cdp enable
interface FastEthernet0/5
no cdp enable
interface FastEthernet0/6
no cdp enable
interface FastEthernet0/7
no cdp enable
interface FastEthernet0/8
no cdp enable
interface FastEthernet0/9
no cdp enable
--More--   spanning-tree portfast
interface FastEthernet0/10
no cdp enable
interface FastEthernet0/11
no cdp enable
interface FastEthernet0/12
no cdp enable
interface GigabitEthernet0/1
description 2950A - Uplink
switchport trunk allowed vlan 1,8,269,1002-1005
switchport mode trunk
interface GigabitEthernet0/2
interface Vlan1
no ip address
no ip route-cache
shutdown
interface Vlan8
ip address 10.34.8.3 255.255.255.0
ip helper-address 10.34.144.193
no ip route-cache
ip default-gateway 10.34.8.1
ip http server
line con 0
password 7
login
transport input none
stopbits 1
line vty 0 4
password 7
login
 line vty 5 15
password 7
login
ntp clock-period 17180563
ntp server 10.34.2.1 prefer
ntp server 17.151.16.21 key 0 prefer
ntp server 10.34.144.1
end
chrihussey
Not familiar with the 2950 switches, but you may have to configure the port with a voice VLAN and as a trunk. I know this was the case in the older 3550 switches. See the attached link:
http://www.cisco.com/c/en/us/support/docs/switches/catalyst-2950-series-switches/113260-voice-vlan-00.html
The document does state that "By default, a switch port drops any tagged frames in hardware", which would explain what you are experiencing.
chrihussey
That was it.  Thanks.  I trunked the port and the phone came right up.  Thanks again.
