Voltage low alarm in Transceiver
jc.saavedra
I have  the follow error in a SW3750:
%SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Voltage low alarm; Operating value: 0.00 V, Threshold value: 3.07 V.
I used the command:
#sho interfaces transceiver
If device is externally calibrated, only calibrated values are printed.
++ : high alarm, +  : high warning, -  : low warning, -- : low alarm.
NA or N/A: not applicable, Tx: transmit, Rx: receive.
mA: milliamperes, dBm: decibels (milliwatts).
                                 Optical   Optical
           Temperature  Voltage  Tx Power  Rx Power
Port       (Celsius)    (Volts)  (dBm)     (dBm)
Te1/0/1      33.8       0.00      -2.5      -2.5
Te2/0/1      34.7       0.00      -2.5      -1.5
and
#sho interfaces t1/0/1 transceiver
ITU Channel not available (Wavelength not available),
Transceiver is internally calibrated.
                                 Optical   Optical
Te1/0/1      33.7       0.00      -2.5      -2.5
The alert is send every 2 mins.
is possible configure the threshold  ?
Thanks.
smehrnia
Level 7
Level 7
do you get the same error on the other end?
usually, these errors could pop up 'coz of a bad or Non-Cisco GBIC modules.
try to relocate or replace gbic's and see if u r still getting the same error.
and if there is nothing wrong with the connection and you just get these warning messeages you could just filter them:
logging discriminator LOGFILTER mnemonics drops SFF8472-5-THRESHOLD_VIOLATION
logging buffered discriminator LOGFILTER 4096
logging console discriminator LOGFILTER
logging monitor discriminator LOGFILTER
plz Rate if it helped,
Soroush.
Hope it Helps!
Soroush.
smehrnia
Level 7
Level 7
Soroush.
Hope it Helps!
Soroush.
