03-18-2011 05:58 AM - edited 03-06-2019 04:08 PM
Hi There,
We currently have dual-homed 2148's to 5010's and are now looking to add another pair of 2148's as single homed to provide vPC connectivity to dual attached Servers as below.
5010-A ----------------- 5010-B
2148-A 2148-B
Fex102 Fex103
| Server |
I have had a look at the attached document and need some clarification. Can I have different FEX numbers 102 (on 5010-A) and 103 (on 5010-B) or do they both have to be the same as indicated in the document (FEX100) ?
Thanks in advance for any help.
Jim.
Solved! Go to Solution.
03-18-2011 11:00 AM
Hi Jim,
You can have different FEX numbers. That is how I have it setup in my lab. I did it mainly to avoid confusion as to where the port belongs when I just look at port numbers.
This is really no different than making a vPC on two 7k's using different linecards on each.
I can post my configs as well, but they are nothing fancy.
Hope that helps
03-18-2011 11:00 AM
Hi Jim,
Hope that helps
03-19-2011 05:10 AM
Thanks Chad,
That has cleared things up for me.
Jim.
