12-12-2019 10:08 PM
I have the following scenario, two nexus 9K are configured as vPC peers with HSRP, the upstream is connected to active/standby firewall with OSPF configured.
below is the configuration;
SW1 & SW2
router ospf 1
bfd
router-id 10.10.10.4
area 0.0.0.4 nssa no-summary
interface Vlan20
ip ospf dead-interval 3
ip ospf hello-interval 1
ip ospf network point-to-point
ip router ospf 1 area 0.0.0.4
ip ospf bfd
interface Vlan20
hsrp 20
ip 20.20.20.1
vpc domain 10
peer-switch
role priority 100
peer-keepalive destination 10.10.10.2 source 10.10.10.1 vrf vpcvrf
peer-gateway
layer3 peer-router
auto-recovery
ip arp synchronize
interface port-channel1
vpc peer-link
Switch one neighbor is flapping between EXSTART and EXCHANG
Neighbor ID Pri State Up Time Address Interface
10.10.10.5 1 FULL/ - 00:25:17 20.20.20.3 Vlan20
10.20.10.10 1 EXCHANGE/ - 0.065025 20.20.20.6 Vlan20
Please advice if the above configuration is correct.
Solved! Go to Solution.
12-14-2019 01:17 PM
Hello
Are you running 9Ks?
12-14-2019 01:33 PM
12-14-2019 04:38 PM
Hello
well then it seems L3 over vPC is now applicable however I would suggest if you can to have a separate L3 for you backup path between switches instead of using the and svi over peer-link
12-15-2019 05:05 AM
12-21-2019 05:52 AM
You are right, your setup is valid and supported assuming you have the required minimum software version on the N9K.
However within your vlan20 you have 3 OSPF neighbors so this is obviously no P2P network. As such the "ip ospf network point-to-point" configuration needs to be removed.
And you don't need hsrp there, it is just cluttering your configuration.
01-05-2020 06:15 AM
