Vpc and enhanced Vpc
raj.kumar
I need to check if my nexus 5548UP is running Vpc or enhanced Vpc. Is there a command to verify that
I have NXOS 5.1(3)N2(1) running on this switch
raj
Reza Sharifi
Enhanced VPC is supported starting with Nexus OS version 5.1(3)N1(1)
I need to check if we are using Vpc or enhanced Vpc in the switch. Is there a command or configuration which verifies that
As far as I know, there is no such a command to verify if you are running VPC or eVPC. The show commands for vpc are just "show vpc" or "show vpc keep-alive" etc..
i am trying to see how to check this..there should be some way
