vPC between 2 redundant sets of nexus 5020
tiwang
Level 3
Level 3
Hi out there
we are running a a redundant set of nexus 5020 nxos 4.2.1 and another set running 5.0.3. They are inter-connected with 2 10GB fiberlinks with 50km's between given a latency of approximately ½ mSec - is there anything special to be aware of in this setup?
Can some help me with a sample setup - the setup should looke like this:
nx5k1-1 <----------------50km fiber link 1----------------------> nx5k2-1
I        I
I vpc domain 10        I vpc domain 11
I                       vPC connection  between sites                     I
I        I
I peerlink for   vPC dom 10                                                    I peerlink for vPC dom 11
I        I
nx5k1-2 <-------------------50km fiber link 2---------------> nx5k2-2
best regards
thomas iwang
16 Replies 16
Ok its not available yet , thx, I already saw some sample-config with peer-switch command for Nexus5000 (probable a copy paste error from a N7K config)
so I assume the system priority and the system mac under the vpc config is only used for LACP , correct ?
Thx
Hubert
You are correct for both system-priority and system-mac usage.
HTH,
jerry
