vPC card type on Nexus
VuongNguyen2903
Hi everyone,
I have a question for vPC of paramater. It is vPC card type. What does this mean? I can configure to change it or it's related with hardware and not change? Thank you for your support.
#show vpc consistency-parameters vpc 25
vPC card type   1   N9K TOR   N3K
6 Replies 6
balaji.bandi
vPC card type   1   N9K TOR   N3K  (this is not the full output - if you can see the full output)   <--- this how the VPC established using Type 1 hardware using (Local) Nexus 9K TOR (Topr of the rack) other side (Remote) Nexus 3K .
BB
thanks. i can change vPC card type. Example: N3K become N9K TOR for parameter match.
Yes it can because card type or the nexus platform compatibility. Can I know more details about cards
what command i can use for change vPC card type? Ex: N3K become N9K TOR?
1- Solved: VPC between different models in N9K series - Cisco Community
2- the Card is not SW config it totally different HW consideration
what command i can use for change vPC card type? Ex: N3K become N9K TOR?   <-- you can not change
BB
