vPC configuration issue
kalugotla1
Level 2
Level 2
trying to configure vPC on nexus 5K running into issues.
                 PeerLink
Nexus5KA-----------------Nexus 5KB
Nexus2KA               Nexus2KB
                 Cisco Load Balancer
     Need to connect my cisco load balancer  interfaceGi1/1 --        interface Ethernet138/1/2 on nexus 2KA
        InterfaceGi1/2---interface Ethernet138/1/2 on nexus 2KB
need to configure vPC for the making load Balancer highly redundant
Here is the config i had on my 5Ks,able  to create a peer link and flex fabric ,but running into issues with vPC
looks like configured everything but vpc is not working.
Nexus 5K A:
vpc domain 2
  role priority 100
  system-priority 100
  peer-keepalive destination 10.18.168.72 source 10.18.168.71
interface port-channel101
  description PPPPPPPPPP-Eth 1/1, Eth 1/2-PPPPPPPPPPPPP
  switchport mode trunk
  vpc peer-link
  switchport trunk allowed vlan 1,10,200
  spanning-tree port type network
  speed 10000
interface port-channel110
  vpc 110
  switchport trunk allowed vlan 200
interface Ethernet1/1
  description PortChannelPortChannel 5kb 1/1,1/2 PortChannelPortChannel
  channel-group 101 mode active
interface Ethernet1/2
fex 138
  pinning max-links 1
  description FEX0138
interface Ethernet1/38
  fex associate 138
  switchport mode fex-fabric
Nexus5KB:
vpc domain 2
  role priority 200
  system-priority 100
  peer-keepalive destination 10.18.168.71 source 10.18.168.72
  vpc peer-link
  speed 10000
  description PortChannelPortChannel 5ka 1/1,1/2 PortChannelPortChannel
fex 138
  pinning max-links 1
  description FEX0138
  fex associate 138
ACE :
interface gigabitEthernet 1/1
  description conn to nex2kA
channel-group 110 mode active
  no shutdown
interface gigabitEthernet 1/2
  description conn to nex2kB
  no shutdown
7 Replies 7
andtoth
Level 9
Level 9
Could you please be a bit more specific about what issues you're observing?
Please paste the output of the following commands.
show port-channel summary
show vpc
show vpc consistency-parameters global
Best regards,
Andras
Here is the output
sw5ka# sh vpc
Legend:
                (*) - local vPC is down, forwarding via vPC peer-link
vPC domain id                   : 2
Peer status                     : peer adjacency formed ok
vPC keep-alive status           : peer is alive
Configuration consistency status: success
vPC role                        : primary
Number of vPCs configured       : 2
Peer Gateway                    : Disabled
Dual-active excluded VLANs      : -
vPC Peer-link status
id   Port   Status Active vlans
1    Po101  up     1,101-102,817,997
vPC status
id     Port        Status Consistency Reason                     Active vlans
110    Po110       down*  success     success                    -
139    Po139       up     success     success                    1,101-102,8
        17,997
5ka# show port-channel summary
Flags:  D - Down        P - Up in port-channel (members)
        I - Individual  H - Hot-standby (LACP only)
        s - Suspended   r - Module-removed
        S - Switched    R - Routed
        U - Up (port-channel)
Group Port-       Type     Protocol  Member Ports
      Channel
101   Po101(SU)   Eth      LACP      Eth1/1(P)    Eth1/2(P)
110   Po110(SD)   Eth      LACP      Eth138/1/25(I)
139   Po139(SU)   Eth      LACP      Eth1/39(P)   Eth1/40(P)
5ka# sh vpc consistency-parameters global
    Legend:
        Type 1 : vPC will be suspended in case of mismatch
Name                        Type  Local Value            Peer Value
QoS                         1     ([], [3], [], [], [],  ([], [3], [], [], [],
Network QoS (MTU)           1     (1538, 2240, 0, 0, 0,  (1538, 2240, 0, 0, 0,
                                  0)                     0)
Network Qos (Pause)         1     (F, T, F, F, F, F)     (F, T, F, F, F, F)
Input Queuing (Bandwidth)   1     (50, 50, 0, 0, 0, 0)   (50, 50, 0, 0, 0, 0)
Input Queuing (Absolute     1     (F, F, F, F, F, F)     (F, F, F, F, F, F)
Priority)
Output Queuing (Bandwidth)  1     (50, 50, 0, 0, 0, 0)   (50, 50, 0, 0, 0, 0)
Output Queuing (Absolute    1     (F, F, F, F, F, F)     (F, F, F, F, F, F)
Priority)
STP Mode                    1     Rapid-PVST             Rapid-PVST
STP Disabled                1     None                   None
STP MST Region Name         1     ""                     ""
STP MST Region Revision     1     0                      0
STP MST Region Instance to  1
VLAN Mapping
STP Loopguard               1     Disabled               Disabled
STP Bridge Assurance        1     Enabled                Enabled
STP Port Type, Edge         1     Normal, Disabled,      Normal, Disabled,
BPDUFilter, Edge BPDUGuard        Disabled               Disabled
STP MST Simulate PVST       1     Enabled                Enabled
Allowed VLANs               -     1,101-102,817,997      1,101-102,817,997
Local suspended VLANs       -     -                      -
s0labsw5ka#
Do you have vlan 200 allowed through your peer-links (port101)? I do see it on your initial configs but then again I did not see other vlans allowed like you have here so did you change you initial configuration or is that just a partial configuration to show that you do have those vlans going through?
  vpc peer-link
  speed 10000
Second question is are you using a ACE4710 appliance?  If so I thought LACP and PAGP was not supported on them. (see ACE 4710 Design Guide.pdf)
The way we have our LB connected to our Nexus in a vPC is that we have our ACE 4710 configured in port-channel mode on not using LACP and on our Nexus we have it also on port-channel mode on.  It works fine.
interface Eth138/1/25
channel-group 110 mode on
hope this helps....
-E
eshinjiryu
Community Member
Yes ,Vlan200 is trunked between the peers.
Emil Versoza
Configured port channel on ACE1 .
  channel-group 110
  no shutdown
  channel-group 110
  no shutdown
interface port-channel 110
  switchport trunk allowed vlan 817
  no shutdown
I am struck with another issue i.e ,How to setup the standby ACE for vPC ,as initially ,I though of creating another portchannel on my nexus for ACE2,but later on realised that it will have the exact copy of config as that of active.
If the active fails ,how will the standby takeover on the nexus5K with vPC on please help me.
Hi Kalugotla1
you are right go ahead on the nexus create another vPC for the standby ACE.  The ACEs will communicate thru the FT Vlan if active is unresponsive a switchover will occur.
hope this helps.
