Point-to-Multipoint with Switches ARP
caytos1989
Guys, I really need some help with this topology:
All the devices conected on the switches can reach OTHER networks through a router conected on the Switch Core, however, the PCs connected on the Switches A, B, or C, cant communicate with each other.....I also have IP Phones connected on the three switches...and there is NO audio when any of the phones on the Switches A,B,C call another phone on the Switches A,B,C
I've come to the conclusion that the problem is because when the devices send an ARP request (broadcast) from any of the Switches A,B,C, it goes to the Wi-LAN configured as MASTER, and sends it to the Switch Core...and because it is a broadcast...it wont send it back again through Port Fa0/6, so it never receives the MAC-ADDRESS of the device its trying to go....
Here are the configs of the Switches:
SWITCH CORE
interface FastEthernet0/6
description Point-Multipoint
switchport trunk native vlan 2036
switchport trunk allowed vlan 2036,2136
switchport mode trunk
speed 100
duplex half
SWITCH A
interface GigabitEthernet0/1
SWITCH B
media-type rj45
speed 100
duplex half
SWITCH C
interface FastEthernet0/24
PLEASE HELP!..
Roman Rodichev
Level 7
Level 7
it's your wireless bridge's job to redirect broadcast frames (including ARP) to the other two bridge links. It shouldn't have to send them up to the switch. I would recommend contacting Pulse to check while that's not working.
Roman Rodichev
Level 7
Level 7
So, after going through the Web Admin Page of the Wi-Lan configured as Master...i found an option that said: Repeater Mode: OFF...
Changed that to ON!
and it worked!! had nothing to do with the switches!....
Thank you guys!
Gurpreet Kochar
I am not sure about the working of these wireless devices, but do you think if we convert the requests from broadcast to unicast, it should work ???
