09-12-2013 10:14 AM - edited 03-07-2019 03:26 PM
I know the purpose of VPC is to have more than one switch for the peer and keep-alive, etc..
But i have an envrionment that has multple IOS switches connected to the nexus 5k switch. Should I or Can I create a vpc domain on a single nexus to use the features of VPC? or should I just create port-channels on the nexus 5k to the IOS switches?
Solved! Go to Solution.
09-12-2013 12:21 PM
If you only have a single Nexus, you would not be using theVPC (Virtual Port Channel) function. You would just create standard port channels.
09-12-2013 12:21 PM
09-12-2013 05:57 PM
AS Gregory said you can use the Port-Channel for this.
VPC comes in to picture when you are connecting the switches to different N5k.
Inayath.
09-13-2013 02:07 PM
Thank you
