VPC error after upgrading Nexus 9K
Hi all,
I have upgrade a pair of Nexus switches from nxos.7.0.3.I4.5.bin to nxos.9.3.11.bin and I am seeing an error in the logs.
Routing adjacency over vPC detected without required configuration.Please configure layer3 peer-router under th
e vPC domain.
I have compared the configuration in notepad++ and nothing seems to be missing.
There are a few vpc's showing as down, I did not check if there were previously up.
vPC status
Id Port Status Consistency Reason Active vlans
11 Po11 down* success success -
12 Po12 down* success success -
13 Po13 down* success success -
14 Po14 down* success success -
15 Po15 up success success 1,91,95,104,200,
335
16 Po16 up success success 1,91,95,104,200,
335
17 Po17 up success success 1,27-29
18 Po18 up success success 1,27-29
20 Po20 down* success success -
Is there something that needs applying after the upgraded?
7 Replies 7
e vPC domain.
from this log Message you need both Layer3 peer-router and peer-getaway to make N9K use peer-link for routing protocol
What commands would be needed for this?
Two comamnd
Layer3 peer-router
Peer-gateway
These command add under vpc domain
Would not having this configured on both vpc domains prevent BGP from establishing?
Do not believe this command was there before upgrade.
This is the current VPC configuration
vpc domain 101
role priority 32667
system-priority 32667
peer-keepalive destination 169.254.0.2 source 169.254.0.1 udp-port 3200 vrf management interval 1000 timeout 5 precedence 6 hold-timeout 3
delay restore 60
no delay peer-link
no dual-active exclude interface-vlan
peer-gateway
no layer3 peer-router
layer3 peer-router syslog interval 3600
graceful consistency-check
auto-recovery reload-delay 240
delay restore interface-vlan 10
delay restore orphan-port 0
no fast-convergence
port-channel limit
no shutdown
ip arp synchronize
interface port-channel1
vpc peer-link
interface port-channel5
vpc 5
interface port-channel6
vpc 6
interface port-channel7
vpc 7
interface port-channel10
vpc 10
interface port-channel11
vpc 11
interface port-channel12
vpc 12
interface port-channel13
vpc 13
interface port-channel14
vpc 14
interface port-channel15
vpc 15
interface port-channel16
vpc 16
interface port-channel17
vpc 17
interface port-channel18
vpc 18
interface port-channel19
vpc 19
interface port-channel20
vpc 20
interface port-channel51
vpc 51
interface port-channel52
vpc 52
interface port-channel53
vpc 53
interface port-channel54
vpc 54
interface port-channel55
vpc 55
Ther is no so this command is disable
