vPC Etherchannel between Nexus and Arista switches(LACP)
praun
Would you recommend this setup instead.
Alt .1
On Nexus:
Create the vPC 1830(Arista #1) and corresponding Port-channel + interface 8/30 on both Nexus)
Create the vPC 1831(Arista #2) and corresponding Port-channel + interface 8/31 on both Nexus)
and use an ordinary ether-channel uplink on each Arista. And quit the MLAG between the 2 Arista.
Would this be a better solution?
Trying to create Etherchannel to Arista switches.
vPC between nexus are up, MLAG between Aristas are up.
From Nexus, one side is up and connected. After port-chanel shut/no shut. both sides from nexus is in state linkFlapE.
See Nexus and arista configs below.
Has anyone seen this problem? What is misconfigured?
Nexus config (both sides equal)
interface port-channel1830
  switchport
  switchport access vlan 3842
  spanning-tree port type normal
  spanning-tree bpduguard enable
  mtu 9216
  storm-control broadcast level 10.00
  storm-control multicast level 10.00
  vpc 1830
interface Ethernet8/30
  mtu 9216
  channel-group 1830 mode active
  no shutdown
Arista config (one side)
vlan 4000
   trunk group mlagpeer
interface Port-Channel20
   description mlag peer connection
   switchport mode trunk
   switchport trunk group mlagpeer
interface Port-Channel100
   switchport mode access
   mlag 100
interface Ethernet1
   description uplink1
   channel-group 100 mode active
interface Ethernet2
   description uplink2
interface Vlan4000
   description mlag peer link interface
   no autostate
   ip address 10.0.0.2/30
mlag configuration
   domain-id nan-mlag
   local-interface Vlan4000
   peer-address 10.0.0.1
   peer-link Port-Channel20
15 Replies 15
Mark Malone
I would have thought the Nexus E8/30 interfaces going to Arista would be terminating on 1 switch not 2 locally and the Nexus side configured as vpc going back to the arista if your trying to create etherchannel as you cant really have them split across multiple switches in that vpc design , I could be wrong but that's the ways ours are setup and they work with the likes of dell,hps etc on the connecting side to the nexus switches
Hi Mark.
I have made an alternative as i understand you. Then i don't have to use multi chassis Arista (MLAG)
See new picture.
Is this setup working for you?
Steve Fuller
Level 9
Level 9
In a similar vein to Mark, I don’t quite understand the connectivity you have.
If you have Ethernet 8/30 from both N7010 left and N7010 right connected to a single Arista switch, then whilst it’s vPC on the Nexus, it’s not MLAG on the Arista. This should simply be a standard LAG on the Arista.
You would only need MLAG on the Arista if you’re connecting as shown in the diagram with N7010 left Ethernet 8/30 connected to Arista left Ethernet 1, and N7010 right Ethernet 8/30 connected to Arista right Ethernet 1. Then you would need to have Ethernet 1 interface of both Arista switches configured as part of the MLAG.
Hi Steve.
I see your point. The only reason Eth 1 and Eth2 on each arista are parts of Channel-group 100 is that they have prepared 2x10G to each Nexus.
As shown in the picture there are 2 Arista switches connected to 2 nexus 7010 switches.
Eth 1 from arista 1 goes to nexus 1
Eth 1 from arista 2 goes to nexus 2
Eth 21-24 interconnects the 2 Arista. in MLAG
Se config below.
Thanks for your interrest.
Arista config.
interface Ethernet21
channel-group 20 mode active
interface Ethernet22
interface Ethernet23
interface Ethernet24
interface Vlan4000
no autostate
no ip routing
mlag configuration
domain-id nan-mlag
I’m still not clear on how the configurations match the diagram. The diagram seems to indicate port-channel 1830 as the vPC peer-link i.e., it’s shown on the link between the Nexus 7010, but then you’re showing Ethernet 8/30 with channel-group 1830 i.e., part of port-channel 1830 using vpc 1830 towards the Arista.
Can you post a show vpc from both Nexus switches?
If it helps, I previously posted a working configuration to the post Nexus vPC to Arista MLAG  so perhaps you can use that as a template?
Hi again.
Thansk for your template
Here is the show vPC 1830 and show interface status from both Nexus
I have also enclosed a chart, comparring the 2 Arista and the Nexus as well.
I see no differences from your working example.
Port E1 from each Arista is linked to E8/30 on each Nexus
Nexus #1
sh vpc 1830
vPC status
id   Port   Status Consistency Reason                     Active vlans
1830 Po1830 up     success     success                    3842
sh inter e8/30 status
Port          Name               Status    Vlan      Duplex  Speed   Type
Eth8/30       EMC-DC1-M30        connected 3842      full    10G     10Gbase-LR
Nexus #2
sh vpc 1830
vPC status
1830 Po1830 down* success success -----
sh int e8/30 status
Eth8/30       EMC-DC1-M30        linkFlapE 3842      auto    auto    10Gbase-LR
One port on Nexus always retur to status linkFlapE
Arista 1Arista 2
vlan 4000vlan 4000
   trunk group mlagpeer   trunk group mlagpeer
interface Vlan4000interface Vlan4000
   description mlag peer link interface   description mlag peer link interface
   no autostate   no autostate
   ip address 10.0.0.2/30   ip address 10.0.0.1/30
mlag configurationmlag configuration
   domain-id nan-mlag   domain-id nan-mlag
   local-interface Vlan4000   local-interface Vlan4000
   peer-address 10.0.0.1   peer-address 10.0.0.2
   peer-link Port-Channel20   peer-link Port-Channel20
interface Port-Channel20interface Port-Channel20
   description mlag peer connection   description mlag peer connection
   switchport mode trunk   switchport mode trunk
   switchport trunk group mlagpeer   switchport trunk group mlagpeer
interface Ethernet21interface Ethernet21
   channel-group 20 mode active   channel-group 20 mode active
interface Ethernet22interface Ethernet22
interface Ethernet23interface Ethernet23
interface Ethernet24interface Ethernet24
interface Port-Channel100interface Port-Channel100
   description Uplink   description Uplink
   switchport mode access   switchport mode access
   mlag 100   mlag 100
interface Ethernet1interface Ethernet1
   description Uplink1   description Uplink1
   channel-group 100 mode active   channel-group 100 mode active
interface Ethernet2interface Ethernet2
   description Uplink2   description Uplink2
Nexus 7010 #1Nexus 7010 #2
vpc domain 5
  peer-switchvpc domain 5
  role priority 1000  role priority 2000
  system-priority 3  system-priority 3
  peer-keepalive destination 10.1.1.2
source 10.1.1.1 vrf vPC-peer-keepalive
  peer-keepalive destination 10.1.1.1
source 10.1.1.2 vrf vPC-peer-keepalive
  peer-gateway  peer-gateway
  auto-recovery  auto-recovery
  ip arp synchronize  ip arp synchronize
interface port-channel10interface port-channel10
  description vPC peer-link  description vPC peer-link
  switchport  switchport
  switchport trunk allowed vlan 1101-1400,
2000-2399,2500-3399,3500-3899
  spanning-tree port type network  spanning-tree port type network
  mtu 9216  mtu 9216
  port-channel port load-defer  port-channel port load-defer
  vpc peer-link  vpc peer-link
interface Ethernet1/26interface Ethernet1/26
  rate-mode dedicated force  rate-mode dedicated force
  mtu 9216  mtu 9216
  channel-group 10 mode active  channel-group 10 mode active
  no shutdown  no shutdown
interface Ethernet2/26interface Ethernet2/26
  mtu 9216  mtu 9216
interface port-channel1830interface port-channel1830
  inherit port-profile xxxx  inherit port-profile xxxx
  description EMC-DC1-M30  description EMC-DC1-M30
  switchport access vlan 3842  switchport access vlan 3842
  spanning-tree bpduguard disable  spanning-tree bpduguard disable
  vpc 1830  vpc 1830
interface Ethernet8/30interface Ethernet8/30
  mtu 9216  mtu 9216
  storm-control broadcast level 10.00  storm-control broadcast level 10.00
  storm-control multicast level 10.00  storm-control multicast level 10.00
  channel-group 1830 mode active  channel-group 1830 mode active
In the original post you said "After port-chanel shut/no shut. both sides from nexus is in state linkFlapE". I took this to mean the interface on both Nexus were becoming disabled.
Is it only the one interface on Nexus #2 that becomes disabled? If so this could simply be a media issue, either SFP+ transceiver or fibre. Is it possible to get those checked?
Hi Steve.
I don't think it's a fiber issue. We have 3 sites with the same problems.
It's likly a config problem.
We have tested the fiber and changed SFP's without a change.
The link is behaving strange. Here is a print from the log.
As i Said. The fiber is testet and the SFP+ has been changed:
It toggles between active and link failure several times until error disabled.
Se log
%ETHPORT-5-IF_UP: Interface Ethernet8/30 is up in mode access
%ETHPORT-5-IF_DOWN_LINK_FAILURE: Interface Ethernet8/30 is down (Link failure)
%ETH_PORT_CHANNEL-5-PORT_INDIVIDUAL_DOWN: individual port Ethernet8/30 is down
%ETHPORT-5-SPEED: Interface Ethernet8/30, operational speed changed to 10 Gbps
%ETHPORT-5-IF_DUPLEX: Interface Ethernet8/30, operational duplex mode changed to Full
%ETHPORT-5-IF_RX_FLOW_CONTROL: Interface Ethernet8/30, operational Receive Flow Control state changed to off
%ETHPORT-5-IF_TX_FLOW_CONTROL: Interface Ethernet8/30, operational Transmit Flow Control state changed to off
%ETHPORT-5-SPEED: Interface port-channel1830, operational speed changed to 10 Gbps
%ETHPORT-5-IF_DUPLEX: Interface port-channel1830, operational duplex mode changed to Full
%ETHPORT-5-IF_RX_FLOW_CONTROL: Interface port-channel1830, operational Receive Flow Control state changed to off
%ETHPORT-5-IF_TX_FLOW_CONTROL: Interface port-channel1830, operational Transmit Flow Control state changed to off
%ETH_PORT_CHANNEL-4-PORT_INDIVIDUAL: port Ethernet8/30 is operationally individual
%ETHPORT-5-IF_DOWN_ERROR_DISABLED: Interface Ethernet8/30 is down (Error disabled. Reason:Too many link flaps)
Agreed. It'd be pretty unlucky if this was a fibre / transceiver issue :-)
The error %ETH_PORT_CHANNEL-5-PORT_INDIVIDUAL_DOWN could be indicating that the Nexus is not receiving LACPDU (Link Aggregation Control Protocol Data Units) and so moves the port into what the IEEE standard calls an Individual (I) state. That said I've not seen interfaces disabled due to link flap as a result of that.
What do you see on each switch, both Nexus and Arista, if you run the show lacp counters command? Can you see the counters increasing in all cases or only on those ports that are not being disabled.
Can you also add the command logging timestamps [seconds|milliseconds] to the configuration so we have an idea of time frame between link state changes?
Hi Steve.
Thanks for your reply. Here is an update.
We can now get the link connected by doing a interface shut on both sides. Then first open the Nexus interface and then the Arista interface before the Nexus interface goes into LinkFlap-errordisabled - and the link is up/connected without problems. This is the only way to get connection. So it's likly a LACP problem.
jnrs-sev-109-0201# sh lacp counters int po 1830
                    LACPDUs         Marker      Marker Response    LACPDUs
Port              Sent   Recv     Sent   Recv     Sent   Recv      Pkts Err
port-channel1830
Ethernet8/30       124637 34251    0      0        0      0        0
We have lots of LACP count stepping up.
Shut/noshut on Nexus while Ariste interface is enabled won't bring the interface up.
EMC who is responsible for the Arista switches has verified the Nexus and Arista configs and can't find any misconfigurations. So the problem has been escalatedto Arista tech-support.
Thanks for posting back. I'd be interested to hear what the vendor has to say as I've never had any issues with Cisco vPC to Arista MLAG.
One difference I noticed when I went through this again was that you've configured the port-channel with switchport mode access, but whenever I've configured this I've always used  switchport mode trunk.
Did you ever get a resolution to this problem? I have an almost identical setup (with EMC ECS connected through EMC provided Arista switches, MLAGed to a Nexus 7010 VPC pair) and am experiencing some similar problems.
Steve Fuller
Level 9
Level 9
You said:
"On Nexus:
Would this be a better solution?"
I would continue with the vPC to MLAG configuration. It works well in my experience and means you get the benefits associated with MLAG i.e., no STP and all links forwarding.
I'd go for a "double sided" MLAG where all four link between the Nexus pair and the Arista pair are part of the same Cisco vPC  / Arista MLAG port-channel group.
Based on what you've provided I think the following is the required configuration:
Nexus:
Nexus 7K1
Nexus 7K2
feature vpc
vpc domain <domain_id>
  peer-switch
  role priority 1
  peer-keepalive destination <peer_ip_address>
  delay restore 60
  peer-gateway
  vpc peer-link
interface Ethernet <mod>/<port>
  channel-group 1 mode active
  vpc 1830
interface Ethernet8/31
feature vpc
  peer-switch
  role priority 1
  delay restore 60
  peer-gateway
  vpc peer-link
  vpc 1830
Arista:
Arista #1
Arista #2
vlan 4000
interface Vlan4000
   ip address ip address 10.0.0.1/30
mlag configuration
   domain-id nan-mlag
interface Ethernet <port_x>
interface Ethernet <port_y>
   mlag 100
interface Ethernet1
interface Ethernet2
vlan 4000
interface Vlan4000
   ip address ip address 10.0.0.2/30
mlag configuration
   domain-id nan-mlag
   mlag 100
interface Ethernet1
interface Ethernet2
As an aside, I'd probably be tempted to operate the links between the Nexus and Arista as IEEE 802.1Q trunks. If you only want the single VLAN 3842 at this stage simply add the command switchport trunk allowed vlan 3842 to your port-channel configuration. At least this way if you want to have additional VLANs at a later stage you can simply add them in a way that won't cause any disruption.
Thats correct. I see your point.
But configuring the ports as access ports should work as well.
Agree?
/Regards
