vPC from 6800 to N9K
Network Pro
is it possible to run vPC from 1 x N9k to 2 x Core 6800IA
Core 1 (6800) ---VSS-----  Core 2 (6800
   |___________N9k____________|
                       vPC?
13 Replies 13
Reza Sharifi
Yes, but there is no need for a vPC since you only have one N9k switch. You just need a regular Portchannel.
Thanks for responding but since there is vss between two 6800 how is it possible to vpc n9k? Remember there are 2 x 6800 cores and 1 n9k. I know vice Versa is possible but not this?
if possible what's the config?
If the 6800s are configured as VSS, they are logically one switch.  So, think of connecting one switch to one switch. As for config, its simple Portchannel config:
Here is an example: with
interface 1/1/3 and 2/1/3 as just examples
interface TenGigabitEthernet1/1/3
switchport trunk allowed vlan xxx
switchport mode trunk
channel-group 7 mode passive
interface TenGigabitEthernet2/1/3
interface Port-channel7
The same config on the nexus side with whatever ports you are planning to use.
Yes I understand this, but vPC does not come into play? I have been asked to do vPC but my understanding its not needed and NOT POSSIBLE. is this right ?
let me ask you this question
Is vPC possible from
between two cores 6800(VSS) between them and to 2 x N9k (Downstream switches - layer 2) running vPC between them?
According to your first post, you only have one Nexus 9k.  If that is the case then you don't need vPC.  If you have 2 9ks than you can configure vPC between the 9ks as well as 9ks and VSS.
lets go with 2 x 9ks
so the cores are going to be 6800 with VSS and downstream switch is going to be N9k with vPC - how will this work ? should the n9k be Layer 3 ?
how will the config work ?
Have a look at the this doc for best practice and configs.
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus9000/sw/6-x/interfaces/configuration/guide/b_Cisco_Nexus_9000_Series_NX-OS_Interfaces_Configuration_Guide/b_Cisco_Nexus_9000_Series_NX-OS_Interfaces_Configuration_Guide_chapter_0111.html
seen this but the bit i am unclear about is the N9K communicating with 6800 on VSS
so lets look at the section below N9K - if I attach a switch or dual homed server to both Nexus and vPC between 2 x N9K then it will work which is fine but how is the connection between n9k and 6800 look like ? port channel or vPC ?
Between the 9ks and 6800 VSS, you can just use layer-3 Portchannels.
for example:
nk9-a connects to both 6800 chassis using Portchannel 10 and
nk9-b connects to both 6800 chassis using Portchannel 20.
should this be only layer 3 port-channels? issue i have is only 1 link from Core (6800) to each N9k - will ths work ?
so
6800-----VSS----------6800
N9k1-------vPC-------N9k2
|----------server----------|
            (dual homed)
To do this correctly, you need 4 links between VSS and the 9ks.  I have not tested this will only 2 links and not sure if it works.
i am thinking of using switched links between 6800 and N9k - let me know if you see any issues?
