How can I translate inside networks to a different inside global address to the one assigned to my serial port using NAT overload?
To expand on the title. I have a router connected to an ISP router with a serial connection. I am given 1 public address of 199.199.199.1. How can I use Nat overload to translate all inside network address to that one address. My serial ports have a different IP (172.72.255.241 for my side and 172.72.255.242 for ISP side). All the guides I can find uses nat overload that translates all inside addresses to the address assigned on the serial port. How can I translate the inside networks to 199.199.199.1 instead of 172.72.255.241.
ohh, yes packet tracer is a great simulator but it has software limitations, in real devices you will see all the options, well, you could try just for testing in packet tracert and if the command is available.
Imagine you have one GigaEthernet interface available:
interface g0/1
ip add 199.199.199.1 255.255.255.252  (we are going to change the subnet mask because /32 is not allowed like in loopbacks)
no keepalive     <-- to keep up up the interface
no shutdown
Then complete the config
ip nat inside source list PRIVATE-NET interface lg0/1 overload
Now as you are using packet tracer, on the neighbor router (simulating is the ISP) You should create a static route to know the IP 199.199.199.1
ISP-Router
ip add 199.199.199.1 255.255.255.255 172.72.255.241
In order to know the subnet through the router client.
Not sure if the command is available in packet tracer but in order to check the functionability you could enable a debug: debup ip nat translations.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
7 Replies 7
e.ciollaro
Level 4
Level 4
configure the public ip over a Loopback interf and configure:
ip nat inside source list  ... interface Loopbackxxx overload
It should work
Bye,
enrico
PS Rate if useful
Julio E. Moisa
I agree with e.ciollaro's comment,
Try with this config:
Interface loopback 199
interface serial X/X
ip add 172.72.255.241 255.255.255.252
ip nat outside
interface gX/X
description INTERNAL-NETWORK
ip address a.b.c.d <subnet mask>
ip nat inside
ip access-list standard PRIVATE-NET
permit ip <your internal networks to translate> example:
permit ip 10.0.0.0 0.255.255.255.255
ip nat inside source list PRIVATE-NET interface loopback 199 overload
ip route 0.0.0.0 0.0.0.0 172.72.255.242 name INTERNET
Hope it is useful.
It appears this is not possible using the '?' after "ip nat inside source list 1 interface" the only options are: Ethernet, FastEthernet, GigabitEthernet and Serial. There is no option for loopback
Have you already created the loopback?
R1(config)#ip nat inside source list Private-Nets interface ?
Async Async interface
Auto-Template Auto-Template interface
BVI Bridge-Group Virtual Interface
CDMA-Ix CDMA Ix interface
CTunnel CTunnel interface
Dialer Dialer interface
Ethernet IEEE 802.3
GMPLS MPLS interface
LISP Locator/ID Separation Protocol Virtual Interface
LongReachEthernet Long-Reach Ethernet interface
Loopback Loopback interface
Lspvif LSP virtual interface
MFR Multilink Frame Relay bundle interface
Multilink Multilink-group interface
Null Null interface
Tunnel Tunnel interface
Vif PGM Multicast Host interface
Virtual-PPP Virtual PPP interface
Virtual-Template Virtual Template interface
Virtual-TokenRing Virtual TokenRing
vmi Virtual Multipoint Interface
it should allow you to include it, what router model and IOS you have?
I am using packet tracer with the 2901 router. This is what show up when I do the '?' command: http://imgur.com/HJXfnkW
interface g0/1
no shutdown
ISP-Router
     i configure the nat like this:
ip nat pool 111 199.199.199.1 199.199.199.1 netmask 255.255.255.0
access-list 123 permit ip 10.1.1.0 0.0.0.255 131.108.1.0 0.0.0.255
ip nat inside source list  123 pool 111 overload
it looks well ,is there some problem i mistake .
