VPC link not working with vsphere
martin1801
Hi all!  I'm pretty new to networking, so forgive me if I missed something obvious. I have a new HP Server running ESXi and joined to vsphere.  It has dual NICS and is connected to two Nexus 5000's.  I've connected a port from each NIC to each Nexus with vpc (the switches aren't stacked) and teaming on esxi using IP hashing.  Each link independently works, but as soon as I connect both, I lose access to the server (currently just working on the Managment vlan).  I know LACP is a thing, but our vsphere isn't licensed for it.  My goal is to have teaming working for network redundancy.
port config:
port channel config:
VPC and port channel status.
All the config is the same on both switches.
9 Replies 9
Mark Elsen
 - Check if this info could be useful : https://community.cisco.com/t5/switching/nexus-9396-vpc-with-vmware-esxi-5-5-standard-switch/m-p/2685545#M323515
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Jaderson Pessoa
Hello, please, share below information
show vpc consistency-parameters vpc 217
show interface port 217 brief
its running lacp?
suggestion its to used  "channel-group 217 mode ative/passive" under interface configuration.
Jaderson Pessoa
*** Rate All Helpful Responses ***
if you can share show port-channel summary
it is not running lacp "protocol = none"... because of that it dont mark as up... change mode to active
Jaderson Pessoa
if the HP server not support LACP, then he need to use mode ON,
active/passive is for only LACP
LACP is a standard protocol... for sure HP servers support that...in almost 90% of vendors use lacp as a default protocol when enabled nic team/lag
Jaderson Pessoa
Mark Elsen
 - Also check logs on both Nexus 5000 devices when you (try) to make the connection and check vsphere networking logs too
 M.
       Beauty and terror
      Just keep going
       No feeling is final
