vPC Nexus error LACP with Switch Access
VuongNguyen2903
Hi everyone,
You may give the solution for checking and fixing?
I configured vPC member port on 2 Nexus connect Cisco WS-C3850-48P:
On Cisco WS-C3850-48P:
interface GigabitEthernet2/0/17
switchport mode trunk
channel-protocol lacp
channel-group 103 mode active
interface Port-channel103
On Nexus:
interface Ethernet1/36
channel-group 40 mode active
interface port-channel40
vpc 103
and show log:
%EC-5-L3DONTBNDL2: Gi1/1/17 suspended: LACP currently not enabled on the remote port
6 Replies 6
Mark Elsen
 - You may need to set Port-channel103 on the C3850 in channel mode too , check output of sh etherchan summary (for instance) ,  find out if the 'global portchannel' is seen in the output  ,
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Tks for your support
Are you complete config  vpc domain in both nsk?
Are you run feature lacp in both nsk
Are you use same stp mode in sw and both nsk?
vPC had established. Feature enabled in both nsk. 3 device the same mode stp is RSTP. You can give me to advice
Share
Show port-channel summary
Show stp
            - Also include :  sh etherchan summary
 M.
       Beauty and terror
      Just keep going
       No feeling is final
