vPC peer-switch is enabled (non-operational)
sstrack
We are wondering about a vPC peer-switch setup whis states to be non-operational!
We are running a Cisco Nexus 7010 vPC pair against a Cisco 6500 VSS setup.
The VSS system is the root of the MST (STP).
We have enabled vPC peer-switch feature on the N7ks.
The two N7ks show the following STP states:
nex7010-1# sh spanning-tree summary Switch is in mst mode (IEEE Standard) Root bridge for: none
Port Type Default                        is disable
Edge Port [PortFast] BPDU Guard Default  is enabled Edge Port [PortFast] BPDU Filter Default is disabled
Bridge Assurance                         is enabled
Loopguard Default                        is disabled
Pathcost method used                     is long
PVST Simulation                          is enabled
STP-Lite                                 is enabled
Name                   Blocking Listening Learning Forwarding STP Active
MST0000                      0         0        0          2          2
MST0001                      0         0        0          2          2
2 msts                       0         0        0          4          4
nex7010-2# sh spanning-tree summary Switch is in mst mode (IEEE Standard) Root bridge for: none
STP-Lite                                 is enabled
MST0000                      0         0        0          2          2
MST0001                      0         0        0          2          2
2 msts                       0         0        0          4          4
What could be the reason for that vPC peer-switch feature to be enabled but (non-operational)?!
Thank you for any hint!
kdebrouw
Hi Stephan,
Allow me to clarify myself,  vPC peer-switch has been introduced into the N7k to improve the convergence time during vPC primary peer device failure/recovery. Without the vPC peer-switch feature, vPC primary peer device failure and recovery usually created around 3 seconds of traffic disruption (for south to north traffic). With vPC peer-switch, traffic disruption is lowered to sub-second value because peer device down an up events do not generate any RSTP Sync behavior (from a STP standpoint, there is no change in L2 topology, there is no new RSTP Root election).
Now to comeback on your topology, as the N7k's are not the primary root bridge STP convergence will not be improved by vPC peer-switch as their is no change in the L2 topology when one of the vPC peer devices fails, the Cat6k VSS will remain the root bridge.
Non-operational means that only the vpc primary will be sending and processing STP BPDU and no virtual System ID is used to appear as a single switch.
I hope this answers your questions
Kristof
kdebrouw
When configuring peer-switch the N7k it will  appear as a single STP root in the Layer 2 topology, but since your VSS is the root bridge it states non-operational as peer-switch is only operational on a root bridge.
Please note that the non-operational can also appear when the spanning-tree  prioirty for vlans are not the same on both
sides. If they don't match, it would not become operational.
Kristof
Hi Kristof,
thanks for your reply - that's a very usefull hint!
But this implies that the peer-switch feature could never be used, if there is more than one vPC pair in any kind of STP setup (or could only be used on one (the STP-Root-Owner) vPC pair), or do I miss something?
Do you know what (non-operational) means in that case? Does it just mean it works in the same manner as if it wouldn't have been configured, or could it cause any other unpredictable behaviors?
Thank you in advance!
Greetings, _Stephan
kdebrouw
Hi Stephan,
Kristof
