vPC Port-channels on Nexus
CiscoPurpleBelt
Level 6
Level 6
If you have a pair of 3k or 9k series Nexus that are joined in a vPC domain, can you have a vPC port-channel for a host (server, PC, etc.) that has 1 or more ports in switch A and 1 or more ports in Switch B all part of the same port-channel or are they basically different port-channels (e.g. ports 1-4 on switch A in Po1; ports 1-4 on switch B in Po1 thus making all of these ports on both switches part of the same port channel)?
Reza Sharifi
Yes, you put all 8 ports from both switches in the same Portchannel.
balaji.bandi
yes, vPC design to meet these kind of requirement, suggest to have a look vPC best practice, explained with more Pictorial diagrams.
https://www.cisco.com/c/dam/en/us/td/docs/switches/datacenter/sw/design/vpc_design/vpc_best_practices_design_guide.pdf
BB
Thanks bro!
