09-18-2011 07:51 AM - edited 03-07-2019 02:17 AM
Is it possible to create a VPC to a non Nexus 2k switch, like a blade switch 3110X, or 4510R-E, or do VPCs only work on Nexus2ks (FEX) switches?
thank you
Bill
Solved! Go to Solution.
09-18-2011 09:05 AM
On the Nexus side you configured the portchannel as active. This is LACP
channel-group 40 mode active
On the 4500 side you configured the portchannel as on. This is non-negotiable.
You need to make both sides the same. If you configure the Nexus for LACP (active) then configure the 4500 also for LACP (passive)
09-18-2011 08:14 AM
Bill
Yes, asboslutely. vPCs simply allow you to terminate the portchannel across 2 separate physical Nexus switches. So you would simply configure your etherchannel as normal on your 4510 for example but at the Nexus end the physical links from the 4510 would be split between the 2 Nexus switches.
Obviouslt the advantage of this is that all links in the etherchannel are forwarding to both Nexus switches without the need for STP to block and you still haev redundancy in case of physical link failure.
Jon
09-18-2011 08:30 AM
my physical link is showing up, but the po interface is showing down.
Here's the Nexus side
interface Ethernet1/8
description Link to 4510 port 6/1
switchport mode trunk
switchport trunk native vlan 99
HBG-Nexus5k-1# sh int e 1/8
Ethernet1/8 is up
interface port-channel40
spanning-tree port type network
HBG-Nexus5k-1# sh int po40
port-channel40 is down (No operational members)
Here's the 4510 side
interface TenGigabitEthernet5/1
channel-group 40 mode on
end
interface Port-channel40
description Trunk to Nexus5ks
switchport
end
HBG-4510R-E#sh int tenGigabitEthernet 5/1
TenGigabitEthernet5/1 is up, line protocol is up (connected)
and on the 4510 the po interface shows up and connected...
HBG-4510R-E#sh int po40
Port-channel40 is up, line protocol is up (connected)
thank you
09-18-2011 09:05 AM
09-18-2011 09:27 AM
working, thank you!
