vPC Type-2 inconsistency problem
CATYO
Level 3
Level 3
Hi there.
Now I'm facing Type-2 inconsistency problem.  I don't know what's the problem.
Here is the output.
what should i do to fix this ?
Thank you in advance : )
[7K_1]
switch# show vpc
Legend:
                (*) - local vPC is down, forwarding via vPC peer-link
vPC domain id                     : 1
Peer status                       : peer adjacency formed ok
vPC keep-alive status             : peer is alive
Configuration consistency status  : success
Per-vlan consistency status       : success
Type-2 inconsistency reason       : Consistency Check Not Performed
vPC role                          : secondary
Number of vPCs configured         : 1
Peer Gateway                      : Disabled
Dual-active excluded VLANs        : -
Graceful Consistency Check        : Enabled
Auto-recovery status              : Disabled
vPC Peer-link status
id   Port   Status Active vlans
1    Po1    up     1,101
vPC status
id   Port   Status Consistency Reason                     Active vlans
10   Po10   up     success     success                    1
switch#
switch# show vpc consistency-parameters global
    Legend:
        Type 1 : vPC will be suspended in case of mismatch
Name                        Type  Local Value            Peer Value
STP Mode                    1     Rapid-PVST             Rapid-PVST
STP Disabled                1     None                   None
STP MST Region Name         1     ""                     ""
STP MST Region Revision     1     0                      0
STP MST Region Instance to  1
 VLAN Mapping
STP Loopguard               1     Disabled               Disabled
STP Bridge Assurance        1     Enabled                Enabled
STP Port Type, Edge         1     Normal, Disabled,      Normal, Disabled,
BPDUFilter, Edge BPDUGuard        Disabled               Disabled
STP MST Simulate PVST       1     Enabled                Enabled
Allowed VLANs               -     1,101                  1,101
Local suspended VLANs       -     -                      -
switch#
switch# show port-ch sum
Flags:  D - Down        P - Up in port-channel (members)
        I - Individual  H - Hot-standby (LACP only)
        s - Suspended   r - Module-removed
        S - Switched    R - Routed
        U - Up (port-channel)
        M - Not in use. Min-links not met
Group Port-       Type     Protocol  Member Ports
      Channel
1     Po1(SU)     Eth      NONE      Eth3/1(P)    Eth3/2(P)
10    Po10(SU)    Eth      LACP      Eth3/11(P)
switch#
switch# sh vlan
VLAN Name                             Status    Ports
1    default                          active    Po1, Po10, Eth3/1, Eth3/2
101  VLAN0101                         active    Po1, Eth3/1, Eth3/2
VLAN Type  Vlan-mode
1    enet  CE
101  enet  CE
Remote SPAN VLANs
Primary  Secondary  Type             Ports
switch#
[7K_2]
switch# sh vpc
Legend:
vPC domain id                     : 1
vPC role                          : primary
1    Po1    up     1,101
vPC status
    Legend:
 VLAN Mapping
switch#
switch#  sh run vpc
!Command: show running-config vpc
!Time: Tue Nov 25 07:48:04 2014
version 6.1(2)
feature vpc
vpc domain 1
  peer-keepalive destination 1.1.1.1
interface port-channel1
  vpc peer-link
interface port-channel10
  vpc 10
switch#
switch# show port-ch summary
      Channel
switch#
5K
switch# sh vlan
VLAN Type  Vlan-mode
1    enet  CE
101  enet  CE
Remote SPAN VLANs
switch#
6 Replies 6
PETER BUZA
Hi, as you can see from the output of "show vpc" the Type-2 consistency check not performed. It is probably due to you have not configured any type-2 consistency check related features on your devices that would triggers the type-2 inconsistency check to perform.
You can read more about type-2 consistency parameters here:
www.cisco.com/c/dam/en/us/td/docs/switches/datacenter/sw/design/vpc_design/vpc_best_practices_design_guide.pdf
Peter
BR, Peter
Thank you !! : )
Please check if you have any SVI configured on both Peer devices. if there is no any SVI configured the type 2 consistency check will not perform. So this is expected behaviour if we don't have SVI configured on both switches.
To verify this , please give me below ouput
show ip int brief | ex unas
or you can create SVI on both device and test it.
VS.Suresh.
*Plz rate the usefull posts.
Yes!!!!. there's no SVI : )
Thank you very much.
Awesome . Nice to hear that issue resolved.
Also Please rate and mark as answered so it will useful for others as well.
VS.Suresh
We faced similar issue in N9K.
We enabled feature interface-vlan after which we got type-2 consistency status : Success
Now i disabled feature interface-vlan and still we see type-2 consistency status : Success
