VRF and next-hop selection using Policy Based Routing.
andrea.meconi
Level 2
Level 2
Hello.
I'm using a Catalyst 6500 with SUP720/MSFC3 and software 12.2(18)SXF7.
I need to select a next-hop into a VRF using PBR, but with this version I can only set, or clear, DF bit.
I believe I need to upgrade my software to use the feature multi-VRF selection using PBR.
sw-core(config-if)# ip policy route-map MR-VS-RER
% Policy Based Routing is NOT supported for VRF interfaces
% IP-Policy can be used ONLY for marking (set/clear DF bit) on VRF interfaces
sw-core(config-if)#
Can somebody confirm this?
Thanks.
Regards.
Andrea
Jon Marshall
andrea.meconi@compaq.com
Hello.
sw-core(config-if)#
Thanks.
Regards.
Andrea
Andrea
Correct, Multi-VRF selection using PBR was first available in 12.2(33)SXH1 so you need to upgrade to that IOS or a later version.
Jon
