VRF in Nexus OS
ncowger
I have a pair of nexus 7009s that are my core switches I just added an additional VRF to them so that I can segment a couple VLANs.  I have it working fine, I was just confused about one of the commands, perhaps someone can enlighten me.  At first, I couldn't get static routes working.
Having only used IOS before for VRFs, I used this command (which is similar to the IOS command)
ip route 0.0.0.0 0.0.0.0 172.28.0.5 vrf SecureServer
When that didn't work, I found the following which does work
vrf context SecureServers
  ip route 0.0.0.0/0 172.28.0.5
Can someone explain to me why the first is there and what does it do?  I looked it up in the command reference, which doesn't list "vrf" as an option to the "ip route" command.
http://www.cisco.com/en/US/docs/switches/datacenter/sw/6_x/nx-os/unicast/command/reference/l3_cmds_i.html#wp1556608
Reza Sharifi
Nexus OS is different from the traditional IOS you are used to.  With Nexus, you enter the vrf and than configure the IP route etc... you need.  It is the same for mgmt interface.  The context is called management
vrf context management
ip route x.x.x.x
Yes I know. So what does the first command do?
Aabed Khalifa
Hello ncowger ,
I  am planning to have similar change recently on our DC Nexus switches (7K as well ) , my plan was to use the command
so it's like message for me not to use it
what IOS are using ? and have you experienced any issue with NX regarding VRF's  ?
We are currently on 6.1 (3) we haven't seen any issues using VRFs though I've just done a little bit of testing.  I would say it works as expected.
