VRF Issue
jahilnt10
I'm just testing this out. I have configured two VRF instance. And I'm exporting and importing vrf table from Cust-A to vice versa.
ip vrf Cust-A
rd 1:1
route-target export 1:1
route-target import 1:1
route-target import 2:2
ip vrf Cust-B
rd 2:2
route-target export 2:2
interface FastEthernet0/1/0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
no ip mroute-cache
load-interval 30
full-duplex
no cdp enable
interface FastEthernet0/1/0.1
encapsulation dot1Q 99
ip vrf forwarding Cust-A
ip address 10.192.168.1 255.255.255.0
no cdp enable
interface FastEthernet0/1/0.2
encapsulation dot1Q 169
ip vrf forwarding Cust-B
ip address 10.192.169.1 255.255.255.0
no cdp enable
If I do show ip route vrf Cust-A or Cust-B ..
show ip route vrf Cust-B
10.0.0.0/24 is subnetted, 1 subnets
C 10.192.169.0 is directly connected, FastEthernet0/1/0.2
Routing Table: Cust-A
C 10.192.168.0 is directly connected, FastEthernet0/1/0.1
If i'm importing and exporting route target from both VRf than both VRF should exchange routing table and I must see Cust-A routes in Cust-B VRF table and vice versa..
what i'm doing wrong here...
Second, what if i want my Cust-B users to access internet while internet default route is in global table?
Note: I'm not gonna use any routing protocol for this lab. I just wana use static routing...
royalblues
Level 10
Level 10
I think you have posted the same question in the WAN forum too.
AFAIK, you would require BGP to import the vrfs. You need not do any peering but just enable BGP and respective address families on this switch.
I have done this in my lab and it works out perfectly. I had posted the BGP configs in the WAN forum
Narayan
Please rate all useful posts
