VRF-lite on Catalyst WS-C4510R+E and SUP7E
Thomas Park
Hi, there.
I would like to have VRF running on Cat 4510 switch with one Sup7E.
We have utilized first two ports TenGe5/1-2 as an uplink.
we would like to utilize TenGe5/3 as VRF link.
But for some reason, "ip vrf forwarding" command does not work on any of the TenGe port on Sup7E.
Is this something to do with XE-Os version we are running? or is this something that can't be done on this Sup?
Currently, we are running the XE version 3.02.05SG and has the "entservices" license.
Thank you
Jon Marshall
Thomas
Don't know whether it is supported or not but just a quick check. Did you create the VRF first before trying to place the inteface into it ie.
ip vrf
rd
etc..
Jon
