VRF Routing Issue
nigel doe
Level 2
Level 2
Hi guys,
I'm having problems implementing a vrf on a 3560G (12.2(55)SE9, C3750-IPSERVICESK9-M). I have a number of SVI's configured on the switch and I want to separate routing from one (to start) vlan from the rest.
I think my config looks ok, but when testing the traffic seems to die on the vlan interface. My config looks like this:
ip vrf red
 rd 1:1
interface Vlan11
 description Block 1 Guest WLAN
 ip vrf forwarding red
 ip address 172.16.5.2 255.255.255.0
ip route vrf red 0.0.0.0 0.0.0.0 GigabitEthernet2/0/1 10.201.29.1
ip route vrf red 8.8.8.8 255.255.255.255 GigabitEthernet2/0/1 10.201.29.1
The 10.201.29.1 is an ASA firewall.
What am I missing!?!
Thanks.
edit: It just occurred to me that the exit interface (when traffic returning) won't know about the interface that's not in the global rib and I would need to route back from the global rib to the vrf?
petenixon
Level 6
Level 6
If you add the route back into the global routing table it will solve the return route issue.
petenixon
Level 6
Level 6
Hello
Just like to add you don't need both those statics pointing your FW , Just the default route would do
res
Paul
Kind Regards
Paul
